Active volumes not showing in the GUI
Since 9.1.0 my active volumes are not showing, it's just keeps hanging on Loading...
the pool is just fine, everything works except they are not shown here. Funny thing is they are listed in the sidebar under the Storage->Volumes
I tried exporting the pool in the shell and re-importing it in the FreeNas GUI without luck, issue keeps
Any tricks to get this solved?
Thanks
D
dlavigne
Guest
Which browser and browser version? Does clearing the cache/cookies fix it?
Chrome, latest, just tried some other browsers, same issue.. I do see this message in the shell when I click on the Active Volumes
Aug 20 08:49:23 NAS manage.py: [common.pipesubr:57] Popen()ing: /usr/local/bin/warden list -v
Aug 20 08:50:07 NAS last message repeated 3 times
Not sure if it's related
Thanks
hrzbrg
I didn't want to create a new thread here, but I got the same problem. I ignored it for several months now and thought it would fix itself via updates, but it didn't.
My NAS is a HP N36L with FreeNAS-9.2.0-RELEASE-x64 (ab098f4) running.
[root@casa-nas] ~# zfs list
NAME                                                      USED  AVAIL  REFER  MOUNTPOINT
pool                                                      1.12T  4.06T  953M  /mnt/pool
pool/PluginJail                                            605M  1.41G  605M  /mnt/pool/PluginJail
pool/PluginSoftware                                        395M  1.61G  395M  /mnt/pool/PluginSoftware
pool/casa                                                1.01T  4.06T  1023G  /mnt/pool/casa
pool/herzi                                                107G  917G  107G  /mnt/pool/herzi
pool/jails                                                1.36G  4.06T  139M  /mnt/pool/jails
pool/jails/.warden-template-9.1-RELEASE-amd64-pluginjail  984M  4.06T  984M  /mnt/pool/jails/.warden-template-9.1-RELEASE-amd64-pluginjail
pool/jails/bit_1                                          274M  4.06T  1.22G  /mnt/pool/jails/bit_1
pool/sven                                                18.3M  1024G  18.3M  /mnt/pool/sven
[root@casa-nas] ~# zpool status
  pool: pool
state: ONLINE
  scan: scrub repaired 0 in 1h34m with 0 errors on Sun Feb  2 01:34:45 2014
    NAME                                            STATE    READ WRITE CKSUM
    pool                                            ONLINE      0    0    0
      raidz1-0                                      ONLINE      0    0    0
        gptid/bd5e5f2a-8e3f-11e1-afb6-68b59972ca5b  ONLINE      0    0    0
        gptid/bdfa7a88-8e3f-11e1-afb6-68b59972ca5b  ONLINE      0    0    0
        gptid/be91c9a5-8e3f-11e1-afb6-68b59972ca5b  ONLINE      0    0    0
        gptid/bf29fea0-8e3f-11e1-afb6-68b59972ca5b  ONLINE      0    0    0
errors: No known data errors
Am new to FreeNAS, I am having the same trouble. The volume never shows up in the GUI. Help me out please.
Em new to free nas , I am having the same trouble . the volumes never shows up in the GUI . help me out please
Start by following the Forum Rules you so conveniently overlooked when you signed up. Don't expect any help if all you can say is "I have a problem and need help".
jryan82
I have run into a similar issue, I had a degraded volume which needed a disk replaced (which I've done successfully) however, the volume does not show up in the GUI.
The volume in question is NFS300, and when I post out the status of this volume, it shows up, see output below:
Shell
[root@freenas00 ~]# zpool status NFS300
  pool: NFS300
state: ONLINE
status: Some supported features are not enabled on the pool. The pool can
		still be used, but some features are unavailable.
  scan: resilvered 0 in 0h2m with 0 errors on Wed Jul 12 11:33:37 2017
		NFS300										  ONLINE	   0	 0	 0
			gptid/9797cfe3-a35c-11e5-bbbe-00505689fa58  ONLINE	   0	 0	 0
			gptid/9906e5d2-a35c-11e5-bbbe-00505689fa58  ONLINE	   0	 0	 0
			gptid/9a3732b9-a35c-11e5-bbbe-00505689fa58  ONLINE	   0	 0	 0
		logs
		  da9										   ONLINE	   0	 0	 0
[root@freenas00 ~]#
A search for this issue led me to this post where I ran the SQL cleanup on the volume in question, but it made no changes
Output from sqlquery shows:
[root@freenas00 ~]# sqlite3 /data/freenas-v1.db "select * from storage_volume;"
5669748378765657267|CIF500||ZFS|0|2
[root@freenas00 ~]#
