WashirePie
- Sep 21, 2017
Hello!
First, I am not a networking specialist. But I am willing to learn.
Here's my situation and intention:
Intention
I wanted to have a shared folder, which I can access trough my home network (which works, as of right now) and also have a friend
connect to it from outside my home network trough SSH using Dynamic DNS. I'm hoping to get the SSH access secure by using Public keys. He should also be able to map my shared folder to a drive on his PC using SFTP Net Drive.
Facts
- All clients use Windows 10 Home Edition.
- As for the Server I use a HP Z200 (old business workstation) with FreeNAS-11.0-U3 (c5dcf4416).
- Gave it a static IP in my home network
- Created a single Volume which uses all 4TBs
- Turned on SSH on port 22
- Turned on Dynamic DNS, configured with my No-Ip domain and login
- Created an account which is grouped to "sshd" and has all rights. (No Public key!)
Other notable facts:
- I've forwarded Port 22 to my server
- I've generated a SSH-1 (RSA) key using PuTTygen including a passphrase
- I was able to map the server to a drive using SMTP Net Drive with the local IP and my created account
- I tried putting my public key in the account "SSH Public Key" field and connect trough SFTP Net Drive without luck.
Questions
So, here are my questions:
- I'm still struggeling to access the server trough SFTP Net Drive from outside my home network. Any Ideas?
- How do I set up the Public Keys? Is there something I've missed?I've read about some auth_keys.pbo file. Where is this file located?
- How do I create a folder on my server and set it as my SSH target?
Thanks in advance!
Best regards,
Simon
UPDATE:
Found the authorized keys file in the main directory/.ssh Turns out it automatically generates it if you set a public key for an account
Intention
Facts
- MoBo: HP 506285-001
- CPU: Core i3-540
- RAM: 8GB DDR3
- HDD: 1x 4TB Hitachi Deskstar
- No Drive Controllers
- Onboard Ethernet
Questions
Thanks in advance!
Best regards,
Simon
UPDATE:
