SOLVED A few SSDs don't show up with full capacity
Antoshka
Hello folks,
A few weeks ago I bought 8 Micron SSDs: 4 Micron 5200 Max 960Gb, and 4 Micron 5200 ECO 1.92Tb. All of them come from 3 different sellers. Two of these drives (from one seller) have weird behavior:
1. One disk shows up as a 1.6Tb drive instead of 1.92Tb. I suppose it can have some Over Provisioning or Flex Capacity Micron feature enabled.
2. Another drive shows up as 4Gb instead of 1.92Tb. I don't know what it can be.
What I did:
- I connected drives in Windows and TrueNAS, no difference;
- I tried to format them, but Windows format didn't help, and TrueNAS sg_format gave me an error;
- Successfully updated firmware to the latest.
Here are the details:
1. SMART output
4Gb Drive:
root@NAS[~]# smartctl -a /dev/da14
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p2 amd64] (local build)
Model Family:     Micron 5100 Pro / 52x0 / 5300 SSDs
Device Model:     Micron_5200_MTFDDAK1T9TDC
Serial Number:    203229B1A404
LU WWN Device Id: 5 00a075 129b1a404
Firmware Version: D1MU030
User Capacity:    4,827,996,160 bytes [4.82 GB]
Rotation Rate:    Solid State Device
Form Factor:      2.5 inches
TRIM Command:     Available, deterministic, zeroed
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Thu Feb  2 22:40:41 2023 PST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                ( 6697) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        (  14) minutes.
Conveyance self-test routine
recommended polling time:        (   3) minutes.
SCT capabilities:              (0x0035) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   100   100   050    Pre-fail  Always       -       0
  5 Reallocated_Sector_Ct   0x0032   100   100   001    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       21
 12 Power_Cycle_Count       0x0032   100   100   001    Old_age   Always       -       10
170 Reserved_Block_Pct      0x0033   100   100   010    Pre-fail  Always       -       0
171 Program_Fail_Count      0x0032   100   100   000    Old_age   Always       -       0
172 Erase_Fail_Count        0x0032   100   100   001    Old_age   Always       -       0
173 Avg_Block-Erase_Count   0x0032   100   100   000    Old_age   Always       -       1
174 Unexpect_Power_Loss_Ct  0x0032   100   100   000    Old_age   Always       -       1
183 SATA_Int_Downshift_Ct   0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0032   100   100   000    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       3
194 Temperature_Celsius     0x0022   066   066   000    Old_age   Always       -       34 (Min/Max 19/34)
195 Hardware_ECC_Recovered  0x0032   100   100   000    Old_age   Always       -       0
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   100   100   000    Old_age   Always       -       0
202 Percent_Lifetime_Remain 0x0030   100   100   001    Old_age   Offline      -       0
206 Write_Error_Rate        0x000e   100   100   000    Old_age   Always       -       0
246 Total_LBAs_Written      0x0032   100   100   000    Old_age   Always       -       131277
247 Host_Program_Page_Count 0x0032   100   100   000    Old_age   Always       -       4106
248 Bckgnd_Program_Page_Cnt 0x0032   100   100   000    Old_age   Always       -       511995
180 Unused_Rsvd_Blk_Cnt_Tot 0x0033   000   000   000    Pre-fail  Always       -       6718
210 RAIN_Success_Recovered  0x0032   100   100   000    Old_age   Always       -       0
211 Integ_Scan_Complete_Cnt 0x0032   100   100   000    Old_age   Always       -       6
212 Integ_Scan_Folding_Cnt  0x0032   100   100   000    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
1.6Tb Drive:
Serial Number:    202629AA583B
LU WWN Device Id: 5 00a075 129aa583b
User Capacity:    1,600,321,314,816 bytes [1.60 TB]
Local Time is:    Thu Feb  2 22:46:19 2023 PST
                                        was never started.
                                        been run.
                                        command.
                                        power-saving mode.
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       22
 12 Power_Cycle_Count       0x0032   100   100   001    Old_age   Always       -       180
174 Unexpect_Power_Loss_Ct  0x0032   100   100   000    Old_age   Always       -       173
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       8
194 Temperature_Celsius     0x0022   065   058   000    Old_age   Always       -       35 (Min/Max 17/42)
246 Total_LBAs_Written      0x0032   100   100   000    Old_age   Always       -       62914712
247 Host_Program_Page_Count 0x0032   100   100   000    Old_age   Always       -       1979497
248 Bckgnd_Program_Page_Cnt 0x0032   100   100   000    Old_age   Always       -       361556
211 Integ_Scan_Complete_Cnt 0x0032   100   100   000    Old_age   Always       -       22
No Errors Logged
# 1  Short offline       Completed without error       00%        21         -
2. sg_format
root@NAS[~]# sg_format --format --size=512 /dev/da14 -v --six
    ATA       Micron_5200_MTFD  U030   peripheral_type: disk [0x0]
      PROTECT=0
      Unit serial number:         203229B1A404
      LU name: 500a075129b1a404
    mode sense(6) cdb: [1a 00 01 00 fc 00]
Mode Sense (block descriptor) data, prior to changes:
  Number of blocks=9429680 [0x8fe2b0]
  Block size=512 [0x200]
A FORMAT UNIT will commence in 15 seconds
    ALL data on /dev/da14 will be DESTROYED
        Press control-C to abort
A FORMAT UNIT will commence in 10 seconds
A FORMAT UNIT will commence in 5 seconds
    Format unit cdb: [04 18 00 00 00 00]
Format unit:
Fixed format, current; Sense key: Illegal Request
Additional sense: Invalid field in cdb
Format unit command: Illegal request, type: sense key, apart from Invalid opcode
FORMAT UNIT failed
Any thoughts on what it can be and how to fix it?
Thanks in advance!
Patrick M. Hausen
You wrote you have a Windows system available and can connect the SSDs. I guess just like Samsung and Crucial do, Micron also provides some proprietary "SSD Wizard" tool for Windows.
I would try that to check how it identifies the drives and if possibly you have been given counterfeit products.
Arwen
Linux has a program called hdparm that can reduce the overall size of a SSD to over provision it. Here is an example from one of my SATA SSDs;
# hdparm -N /dev/sdb
/dev/sdb:
 max sectors   = 1953525168/1953525168, HPA is disabled
Here is the relevant man page excerpt for this function;
 -N     Get/set  max  visible  number of sectors, also known as the Host Protected Area setting.  Without a
        parameter, -N displays the current setting, which is reported as two values: the  first  gives  the
        current  max  sectors  setting, and the second shows the native (real) hardware limit for the disk.
One word of caution, it is possible that the seller did not do this "over provisioning". Or that it is simple innocent "over provisioning". On the more paranoid hand, it could be to hide a significant amount of bad blocks. Though, based on the SMART output that does not seem to be the case.
Antoshka
Hi @Patrick M. Hausen,
I don't think it's counterfeit products. I used the official Micron Storage Executive app to update the firmware in all drives. This app detects Micron products and provides matching firmware from the official channel (no manual file loading). The firmware update was successful. The product looks legit. Also, physical warranty labels are in place. I bought 3 drives from this seller, and one of them is fine. Seller doesn't respond me on ebay.
Antoshka
Hi @Arwen,
Thanks, I can set up Linux VM and passthrough HBA with drives, but do you know by any chance FreeBSD/TrueNAS Core alternatives?
Thanks
Antoshka
Yay, it's solved, the seller helped me with a solution:
these two drives showed lower capacity due to Micron Flex Capacity settings. In my screenshot from 1st post, you can see this menu. I tried to see/adjust it when I connected drives to Windows, but the menu was unavailable. And it was unavailable because I connected drives through SATA extensions.
To change Micron Flex Capacity settings, I created Linux VM, passed HBA through with all disks, installed the Micron Storage Executive there, and finally changed Flex Capacity settings.
I hope this thread will be helpful if anyone has the same problem.
Arwen
Great, glad it is solved. Enjoy your SSD drives.
