9.3 beta update crauses kernel panic on reboot
maybe helpful information for stabilizing the coming release
* did a fresh install from the first 9.3 beta ISO --> everything OK
* then did upgrade pending packages from within webGUI
* reboot
* kernel panic because could not re-mount root filesystem (boot media is an usb-stick)
* selecting the first boot entry (9.3 beta) in grub boot menu in order to revert to last working version did work
see screenshots for details
rogerh
If you do a fresh install of the original Beta, does it offer you a very recent upgrade or does it do them incrementally in the order they were released? Some of the early upgrades had a problem with upgrading. I would suggest a new install of the current version of the Beta, or a manual upgrade through the GUI of the current upgrade version. Then you will miss out the early problematic upgrades. This solved the problem for me.
joeschmuck
Old Man
If you install the iso, the next upgrade should be the current and latest upgrade. I personally have the "Automatically check for updates" un-checked. I prefer to wait and manually select the update and this way I can possibly skip a release or two and somewhat control what I'm testing.
J
jkh
Guest
I've never seen anything like that before. Does it panic again if you re-select the boot environment that had the problem? The fact that it can boot OK from the same pool, but not liking a specific dataset (clone) is definitely odd. As I said, that's a totally new one on us.
