paradoxiom
- Jun 16, 2015
Log filling up with:
I had errors like that on another drive and I managed to fix them following this guide:
But it's not working on da1
smartctl of da1:
Any other logs or output I can provide?
The drive is a 2GB Seagate FireCuda SSD.
Aug 30 10:41:30 OrbitallHub smartd[1487]: Device: /dev/da1 [SAT], 4 Currently unreadable (pending) sectors Aug 30 10:41:30 OrbitallHub smartd[1487]: Device: /dev/da1 [SAT], 4 Currently unreadable (pending) sectors Aug 30 11:26:31 OrbitallHub smartd[1487]: Device: /dev/da1 [SAT], 4 Currently unreadable (pending) sectors Aug 30 11:26:31 OrbitallHub smartd[1487]: Device: /dev/da1 [SAT], 4 Currently unreadable (pending) sectors Aug 30 11:26:31 OrbitallHub smartd[1487]: Device: /dev/da1 [SAT], 4 Currently unreadable (pending) sectors Aug 30 12:11:29 OrbitallHub smartd[1487]: Device: /dev/da1 [SAT], 4 Currently unreadable (pending) sectors Aug 30 12:11:29 OrbitallHub smartd[1487]: Device: /dev/da1 [SAT], 4 Currently unreadable (pending) sectors Aug 30 12:11:29 OrbitallHub smartd[1487]: Device: /dev/da1 [SAT], 4 Currently unreadable (pending) sectors Aug 30 12:56:29 OrbitallHub smartd[1487]: Device: /dev/da1 [SAT], 4 Currently unreadable (pending) sectors Aug 30 12:56:29 OrbitallHub smartd[1487]: Device: /dev/da1 [SAT], 4 Currently unreadable (pending) sectors Aug 30 12:56:29 OrbitallHub smartd[1487]: Device: /dev/da1 [SAT], 4 Currently unreadable (pending) sectors Aug 30 13:41:29 OrbitallHub smartd[1487]: Device: /dev/da1 [SAT], 4 Currently unreadable (pending) sectors Aug 30 13:41:29 OrbitallHub smartd[1487]: Device: /dev/da1 [SAT], 4 Currently unreadable (pending) sectors Aug 30 13:41:29 OrbitallHub smartd[1487]: Device: /dev/da1 [SAT], 4 Currently unreadable (pending) sectors
smartctl of da1:
root@OrbitallHub:~ # smartctl -a /dev/da1
smartctl 7.0 2018-12-30 r4883 [FreeBSD 11.3-RELEASE-p11 amd64] (local build)
Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Red
Device Model: WDC WD60EFRX-68MYMN1
Serial Number: WD-WX21D45C7ZSV
LU WWN Device Id: 5 0014ee 2b6d67556
Firmware Version: 82.00A82
User Capacity: 6,001,175,126,016 bytes [6.00 TB]
Rotation Rate: 5700 rpm
ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sun Aug 30 14:23:13 2020 BST
SMART support is: Enabled
General SMART Values:
was never started.
Self-test execution status: ( 121) The previous self-test completed having
the read element of the test failed.
data collection: ( 4604) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 700) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x303d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 15
3 Spin_Up_Time 0x0027 224 196 021 Pre-fail Always - 7783
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 84
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 076 076 000 Old_age Always - 17820
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 84
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 83
193 Load_Cycle_Count 0x0032 199 199 000 Old_age Always - 5111
194 Temperature_Celsius 0x0022 121 107 000 Old_age Always - 31
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 4
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 1
SMART Error Log Version: 1
ATA Error Count: 4
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 4 occurred at disk power-on lifetime: 17781 hours (740 days + 21 hours)
ER ST SC SN CL CH DH
04 51 00 81 f4 2c 00 Error: ABRT
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
b0 d4 00 81 4f c2 00 00 08:28:31.133 SMART EXECUTE OFF-LINE IMMEDIATE
b0 d0 01 00 4f c2 00 00 08:28:31.129 SMART READ DATA
ec 00 01 00 00 00 00 00 08:28:31.126 IDENTIFY DEVICE
ec 00 01 00 00 00 00 00 08:28:31.125 IDENTIFY DEVICE
ec 00 00 00 00 00 00 00 08:28:31.125 IDENTIFY DEVICE
Error 3 occurred at disk power-on lifetime: 17781 hours (740 days + 21 hours)
b0 d4 00 81 4f c2 00 00 08:26:23.971 SMART EXECUTE OFF-LINE IMMEDIATE
b0 d0 01 00 4f c2 00 00 08:26:23.968 SMART READ DATA
ec 00 01 00 00 00 00 00 08:26:23.964 IDENTIFY DEVICE
ec 00 00 00 00 00 00 00 08:26:23.963 IDENTIFY DEVICE
Error 2 occurred at disk power-on lifetime: 17772 hours (740 days + 12 hours)
b0 d4 00 81 4f c2 00 00 16d+16:53:40.267 SMART EXECUTE OFF-LINE IMMEDIATE
b0 d0 01 00 4f c2 00 00 16d+16:53:40.264 SMART READ DATA
ec 00 01 00 00 00 00 00 16d+16:53:40.260 IDENTIFY DEVICE
ec 00 00 00 00 00 00 00 16d+16:53:40.259 IDENTIFY DEVICE
Error 1 occurred at disk power-on lifetime: 17768 hours (740 days + 8 hours)
b0 d4 00 81 4f c2 00 00 16d+13:00:07.165 SMART EXECUTE OFF-LINE IMMEDIATE
b0 d0 01 00 4f c2 00 00 16d+13:00:07.162 SMART READ DATA
ec 00 01 00 00 00 00 00 16d+13:00:07.158 IDENTIFY DEVICE
ec 00 00 00 00 00 00 00 16d+13:00:07.157 IDENTIFY DEVICE
# 1 Short offline Completed: read failure 90% 17806 2824348
# 2 Short offline Completed: read failure 40% 17782 10363944
# 3 Short offline Completed: read failure 90% 17781 2774305
# 4 Short captive Completed: read failure 90% 17781 2717296
# 5 Short captive Completed: read failure 90% 17781 2717296
# 6 Conveyance offline Completed: read failure 90% 17781 2717296
# 7 Conveyance offline Completed: read failure 90% 17781 2717298
# 8 Short captive Completed: read failure 90% 17772 454315400
# 9 Conveyance offline Completed: read failure 90% 17772 454315400
#10 Short offline Completed: read failure 90% 17772 454315400
#11 Short captive Completed: read failure 90% 17768 454315400
#12 Extended offline Completed: read failure 90% 17732 454315400
#13 Extended offline Completed: read failure 90% 17618 454315400
#14 Short offline Completed: read failure 90% 17595 454315400
#15 Short offline Completed: read failure 90% 17571 454315400
#16 Short offline Completed: read failure 90% 17547 454315400
#17 Short offline Completed: read failure 90% 17523 454315400
#18 Short offline Completed: read failure 90% 17499 454315400
#19 Short offline Completed: read failure 90% 17475 454315400
#20 Short offline Completed without error 00% 17458 -
#21 Short offline Completed without error 00% 17427 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
root@OrbitallHub:~ #Any other logs or output I can provide?
