3 out of 9 hard drives fail smartctl in less than 3 months -- what's the deal?
KevDog
I've owned my FreeNAS system for about 4 years now. I have my system setup up with a RAIDZ2 configuration with 1 vdev spanning 8x5Tb WD Red Hard-drives. I have one WD 5tb drive marked as a hot spare.
Within the last 3 months, I've had or am having 3 drive failure. At first it was the Hot spare (which theoretically never gets used), then it was one of the drives in the main pool. I replaced those two drives but now I'm getting another drive failing test 1 of the smartctl short test. Needless to say I'm not happy. At this rate I'll have all the drives fail within a year.
Is this common?
# smartctl -a /dev/da3
smartctl 7.0 2018-12-30 r4883 [FreeBSD 11.3-RELEASE-p7 amd64] (local build)
Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Western Digital Red
Device Model:     WDC WD60EFRX-68L0BN1
Serial Number:    WD-WX11D86KCZF6
LU WWN Device Id: 5 0014ee 2633f0d5d
Firmware Version: 82.00A82
User Capacity:    6,001,175,126,016 bytes [6.00 TB]
Rotation Rate:    5700 rpm
ATA Version is:   ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sun Apr 12 09:56:10 2020 CDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00)    Offline data collection activity
                    was never started.
Self-test execution status:      ( 241)    Self-test routine in progress...
                    10% of test remaining.
data collection:         ( 4784) seconds.
capabilities:              (0x7b) SMART execute Offline immediate.
                    command.
                    Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
Error logging capability:        (0x01)    Error logging supported.
Short self-test routine
recommended polling time:      (   2) minutes.
Extended self-test routine
recommended polling time:      ( 702) minutes.
Conveyance self-test routine
recommended polling time:      (   5) minutes.
SCT capabilities:            (0x303d)    SCT Status supported.
                    SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   197   197   021    Pre-fail  Always       -       9133
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       45
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   100   253   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   063   063   000    Old_age   Always       -       27494
 10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       45
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       43
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       714
194 Temperature_Celsius     0x0022   123   109   000    Old_age   Always       -       29
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed: read failure       60%     27485         3131105000
# 2  Short offline       Completed without error       00%     27317         -
# 3  Short offline       Completed without error       00%     27149         -
# 4  Short offline       Completed without error       00%     26982         -
# 5  Short offline       Completed without error       00%     26814         -
# 6  Short offline       Completed without error       00%     26647         -
# 7  Short offline       Completed without error       00%     26479         -
# 8  Short offline       Completed without error       00%     26311         -
# 9  Short offline       Completed without error       00%     26144         -
#10  Short offline       Completed without error       00%     25994         -
#11  Extended offline    Completed without error       00%       160         -
#12  Extended offline    Completed without error       00%        38         -
#13  Conveyance offline  Completed without error       00%        25         -
#14  Short offline       Completed without error       00%        25         -
Yorick
Jailer
Not strong, but bad
Going by what https://www.overclockers.com/forums...ed-help-figuring-out-SMART-temperature-values explains, your drive is currently at 41 degrees C and the worst temperature it encountered was 55 degrees C.
That seems warm. I’d check all drives for worst temp using formula “(hex to dec) raw + (value - worst)”, and improve cooling
Not sure how you're coming to that conclusion since the line is labeled Temperature_Celsius and has a value of 29. That link you posted sounds like it was from some sort of windows program trying to interpret the smart data.
KevDog
There is nothing I can do about the fans -- there are a total of 7 fans in the case and for the last month the entire case has been open. With seven fans and an open case I'd have to put the machine on ice to make it any cooler.
Yorick
According to everything I can find about smart data, the raw data in general and temperature data for wd drives in particular is given in hex, not dec.
That is a vital distinction. If you have authoritative documents on that, please share.
Redcoat
I'm not sure what you mean by "the entire case has been open", but if that means that the "outer case" has been removed and the system designer's airflow (mass, direction and velocity) from the installed fans is not ensured, then I wouldn't be so sure about the cooling. "open case" suggests natural convection and radiation doing the work - as opposed to forced convection which is significantly more effective...
According to man smartctl, the RAW_VALUE is printed in base-10.
Each Attribute has a "Raw" value, printed under the heading
"RAW_VALUE", and a "Normalized" value printed under the heading
"VALUE".  [Note: smartctl prints these values in base-10.]  In
the example just given, the "Raw Value" for Attribute 12 would
be the actual number of times that the disk has been power-
cycled, for example 365 if the disk has been turned on once per
day for exactly one year.  Each vendor uses their own algorithm
to convert this "Raw" value to a "Normalized" value in the range
from 1 to 254.
Current temp is 29C, worst temp according to the attribute is 43C (123-109+29)
Also, it's easier to check max lifetime temps with smartctl -x /dev/daX and there can sometimes be a little difference between the temperature attribute worst and the max recorded lifetime temp.
Yorick
It's not likely to be a temperature issue, and I'm glad that @Jurgen Segaert set me straight on decimal representation.
Which leaves what? The dreaded "same batch" failure?
That would fit with Backblaze's drive failure data, that shows failure rates increasing after 3 to 4 years - still nothing like "3 drives out of 9" though. My best bet is, if these drives were all bought at the same time, that you are seeing an issue with that batch, that is now showing after 4 years of age.
Other ideas?
Possibly, or just bad luck, another possibility would be abnormal vibatrions, it's also uncommon for the disk to fail without any SMART warnings, not just pending or reallocated sectors but even Raw_Read_Error_Rate and Multi_Zone_Error_Rate are still a perfect 0, these usually start climbing with WD drives before it fails a SMART test.
KevDog
@Johnnie Black. I don't regularly check smartctl results other than those which show up as a warning through the FreeNAS GUI, I'm not sure if that's sufficient. The drives are all probably from the same batch since they were purchased from the same store at the same time -- perhaps it's a batch issue, however this batch issue is starting to get rather expensive.
SweetAndLow
Sweet'NASty
you burn the drives in? badblocks tool? I doubt it's related to any kind of vibration, i think it would have to be shaking the entire case.
SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
This part is indeed very odd... the error rates were not shown in the counters, but the test itself reported 60% remaining, yet complete and with read errors.
That's some kind of indication of the onboard controller not working right in my opinion. Not much you can do about it other than RMA the disk though.
Sadly, that's not an option anymore.
Yorick
Your experience suggests that "shucking" WD external drives, 8TB or greater (where the "Enterprise white labels" are), might make a lot of sense even though they lose all warranty. At least the replacement is affordable. I wonder how common it is for drives to fail outside their warranty period, vs. inside.
Yorick
KevDog
@Yorick -- I just today read report about the SMR drives. I have a replacement drive but haven't yet installed it. What's your resource for looking up the drive number to see if its SMR?
Yorick
KevDog
Argh, since posting this I've yet had another HD fail. That's the fourth one of these WD RED drives. Honestly I'd never purchase WD again. To have four out of 10 drives fail at roughly the four year mark within 6 months on a home system is frankly terrible.
