Hello I was eager to try out 11.2 betas but was a bit miffed by Sonarr being broken in BETA2 and TTRSS not working in BETA3.
I have a whole bunch of random questions regarding plugins and permissions. In 11.1 I ran everything in jails and skipped the built-in extensions.
- Should I create multiple datasets in my pool for each media type? Movies, Music, TV?
- What is the *11.2* best practice for permissions? I will have a mix of official Plugins, my own Jails, and probably some VMs that need access to the data, either write to certain datasets or read only for others.
- How exactly do 11.2 Plugin updates work? When I click "upgrade" it just instantly says "upgrade successful" and doesn't seem to actually do anything.
- How do all of the storage paths like for configs work for plugins? How can I snapshot either the entire Plugin or just its own config data?
- Are people installing the plugins sort of as a template and then tweaking them further via the console? If that's the case would it be better to just run custom jails?
- Is it possible to install multiple instances of the same plugin?
