I need some help setting up my HP micro server with Freenas.
I have followed these guides, but I am still having trouble setting up plugins and their permissions to be able to read and write to the NFS share.
https://forums.freenas.org/index.ph...ssion-and-couchpotato-as-a-dlna-server.17165/
https://forums.freenas.org/index.php?threads/transmission-plugin-installation-and-setup.51498/
http://www.exzacklyright.com/2014/03/newbienoob-guide-to-freenas-plex.html
https://forums.freenas.org/index.ph...plugins-write-permissions-to-your-data.27273/
And numerous forum posts.
Hardware/Software setup:
I have a USB stick plugged directly into the motherboard with FreeNAS version 11.1 installed. (Boot order set so USB is first)
I have 4x 4tb drives – loaded with RAIDZ (I know I only get one disk redundancy)
Plugins installed and their Jails are part of these storage but are separate to my NFS share.
I have created datasets for each folder I want on the share. (TV, Movies, Music, Downloads)
I have given all folders, datasets and storage 777 permissions with ‘nobody’ and ‘nogroup’. I have SSH’d and ran the command ‘chmod –R 777 /../..’ on each folder, dataset and storage.
I have also tried this with Root and Wheel access. I have also tried creating a user with the same UID as the plugins and making it the owner and have read/write access to storage and jails.
I have set up transmission to download to my main NFS share in the configuration, not within its own jail.
When I start the plugin up and test I either get the permissions denied error or it downloads to its own jail storage.
I wiped and started from scratch so many times….
I have used NAS4Free in the past, but thought FreeNAS was a better choice.
What am I doing wrong? Any help will be great!
- Nas
- NAS
- Movies
- TV
- Music
- Movies
- Jails
- Transmission_1
- Warden-template
- Transmission_1
- NAS
