Plex plugin works but won't start
ric
I had a very similar issue where my plex server was running perfectly, but i couldn't stop the service. I would also get "plexmediaserver not running? (check /var/run/plex/plex.pid)." It also showed in the freenas GUI as being turned off even though everything was working fine.
I remember messing with permissions a few days ago by making plex run as media:media. I forgot that might mess things up. So to fix the problem, I just needed to change the permissions on the plex directory: "chown -R media:media /var/run/plex". I also changed the owner of the fcgi file too. Once i did that, I stopped the jail and turned it back on and now everything is working normally. My freenas GUI says its turned on and now I can stop and start the service via putty.
I hope it helps someone who is google searching.
in: /var/run/
old:
drwxr-xr-x 2 plex wheel 2 Dec 10 09:14 plex
-rw-rw-rw- 1 root wheel 5 Dec 10 09:14 plexmediaserver_fcgi_server.pid
new:
drwxr-xr-x 2 media media 2 Dec 10 09:14 plex
-rw-rw-rw- 1 media media 5 Dec 10 09:14 plexmediaserver_fcgi_server.pid
I have same exact problem here, my plexmediaserver won't start (I'm getting "some error occurred" when starting the mediaserver)
The following command didn't work for me either..
"chown -R media:media /var/run/plexmediaserver_fcgi_server.pid".
Joshua Parker Ruehlig
you initial issue was probably networking issues between the FreeNAS webui and the plugin. you should have debugged by trying to ping your computer from the jail, and running 'service plexmediaserver onestart' before changing permissions.
that first command you ran should only be done if you changed the user the plugin runs as to 'media'
the second command should never be run, as the fcgi process is run by root and will never have permission issues.
I suggested you do the following
chown -R plex:plex /var/run/plex
sysrc plexmediaserver_enable=YES
service plexmediaserver start
ric
Also, if I tried to change the permission of below files with same user and group permission (root:ric) on destination folder (mymedia), it says "illegal group name".
plex
ric
I've reviewed
Reverted back permission of below file as instructed:
"chown -R root:wheel /var/run/plexmediaserver_fcgi_server.pid".
ran the following command:
Plexmediaserver still won't start.
ric
I've reviewed
I've reviewed
what was the output of 'service plexmediaserver start' ?
how about 'service plexmediaserver onestatus' ?
ric
[root@freenas] ~# jls
JID IP Address Hostname Path
1 - VBOX /mnt/tank/VBOX
2 - btsync_1 /mnt/tank/btsync_1
3 - couchpotato_1 /mnt/tank/couchpotato_1
4 - customplugin_1 /mnt/tank/customplugin_1 <==== Plexmediaserver
5 - htpc-manager_1 /mnt/tank/htpc-manager_1
6 - nextcloud_1 /mnt/tank/nextcloud_1
7 - owncloud_1 /mnt/tank/owncloud_1
8 - syncthing_1 /mnt/tank/syncthing_1
9 - transmission_1 /mnt/tank/transmission_1
[root@freenas] ~# jexec 4 tcsh
root@customplugin_1:/ # service plexmediaserver start
Starting plexmediaserver.
root@customplugin_1:/ # service plexmediaserver onestatus
plexmediaserver is not running.
can you delete your plex data-directory (in case you messed with the permissions of that too), then try it again
'rm -r /var/db/plexmediaserver
ric
I was able to the start the plugin (plexmediaserver) using "service plexmediaserver start", however it doesn't seem to be available at left menu on freenas gui including Transmission plugin. I even tried restarting my freenas system just to make sure but same results.
since the icon is showing on that page, I'm thinking the fcgi connection is somewhat working. I suggest reloading your browser page.
if that still doesn't work, what I personally always do is disable VIMAGE, assign a network interface to the jail, and restart the jail.
ric
After disabling VIMAGE in the Jail config, and assigned NIC to Jail, Plex finally show up however it doesn't find a way to connect online and plex was able to go outside (WAN) via icmp .
After disabling VIMAGE in the Jail config, and assigned NIC to Jail, Plex finally show up however it doesn't find a way to connect online and plex was able to go outside (WAN).
from the jail can you ping 8.8.8.8 or google.com
maybe the default gateway or DNS isnt setup
ric
Like I said earlier it can go outside my lan. Google.com or 8.8.8.8 is pingable from jail.
if the jail can connect out, I'm not sure why plex can't. I'm not very experienced with plex as I don't use it.
ric
Plex plugin is now able to connect out after system restarted a few attempts. However, I have the same issues on the rest of other plugins which is it wont start.
Thanks!
Thanks!
you could try disabling VIMAGE, setting network interface, and restarting on their jails. then try enabling on the plugins tab.
the way communicating between the FreeNAS webui and the plugins can be flaky, and in my experience VIMAGE makes things worse.
ric
Disabled VIMAGE, still wont start on either way with plugins tab or command line. See below error message.
root@owncloud_1:/ # service owncloud onestart
owncloud does not exist in /etc/rc.d or the local startup
directories (/usr/local/etc/rc.d)
the service name in that case is actually "apache24"
