10gbs switchless bridge issue
Swampass
Hi all, I have a strange problem that I cant seem to figure out. I am attempting to link two R710s(esxi) to a R510(FreeNAS) with a dual 10gbs sfp+ nic. (link to a similar setup)
VMware 6.0 expects each host to see a datastore on the same IP in order for DRS/HA to work, which is why the bridge is necessary instead of configuring two different /30 subnets for each host.
FreeNAS version: 11 u1
FreeNAS nic: HP NC550SFP 10GB 2-Port (latest fw)
ESXi nics: HP 10GB CONNECTX2 single port
FreeNAS to host: oce0 -> esxi02, oce1-> esxi01
The problem I am having is that when i configure the bridge, I get arp traffic to the host via tcpdump, but the host responds and freenas never gets the entry in arp.
currently oce0 is configured in the webui as 10.10.10.2/28, and esxi02 can mount nfs and pass traffic (it also works in reverse if i swap the dac cables esxi01 will work as well)
What am I missing? Any ideas are appreciated.
here is my ifconfig
$ ifconfig bridge0
bridge0: flags=28943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST,PPROMISC> metric 0 mtu 1500
		ether 02:61:6e:08:fe:00
		groups: bridge
		member: oce1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
				ifmaxaddr 0 port 4 priority 128 path cost 2000
		member: oce0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
				ifmaxaddr 0 port 3 priority 128 path cost 2000
$ ifconfig oce0
oce0: flags=8143<UP,BROADCAST,RUNNING,PROMISC,MULTICAST> metric 0 mtu 1500
		options=503bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWFILTER,VLAN_HWTSO>
		ether d4:85:64:23:54:b0
		inet 10.10.10.2 netmask 0xfffffff0 broadcast 10.10.10.15
		media: Ethernet autoselect (10Gbase-SR <full-duplex>)
		status: active
$ ifconfig oce1
oce1: flags=8143<UP,BROADCAST,RUNNING,PROMISC,MULTICAST> metric 0 mtu 1500
		ether d4:85:64:23:54:b4
		status: active
$ arp -a | grep 10.10
? (10.10.10.2) at d4:85:64:23:54:b0 on oce0 permanent [ethernet]
? (10.10.10.3) at (incomplete) on oce0 expired [ethernet]
? (10.10.10.4) at 00:50:56:6a:6a:16 on oce0 expires in 782 seconds [ethernet]
and tcpdump on vmware side answering arp when i ping the host from freenas
$ ping 10.10.10.3
PING 10.10.10.3 (10.10.10.3): 56 data bytes
--- 10.10.10.3 ping statistics ---
5 packets transmitted, 0 packets received, 100.0% packet loss
[root@esxi01:~] tcpdump-uw -i vmk2
tcpdump-uw: verbose output suppressed, use -v or -vv for full protocol decode
listening on vmk2, link-type EN10MB (Ethernet), capture size 262144 bytes
17:45:26.150393 ARP, Request who-has 10.10.10.3 tell 10.10.10.2, length 46
17:45:26.173941 ARP, Reply 10.10.10.3 is-at 00:50:56:68:46:e5 (oui Unknown), length 28
Thomas102
I'm new to FreeBSD, but on linux you must define the IP on the bridge, not on the interface.
In your case on bridge0, not oce0.
Swampass
I have tried assigning an ip only to bridge0, and could not ping it from either hosts. The only way I could get at least one interface to work was assigning an IP in the UI to a nic directly.
I used
 ifconfig bridge0 inet 10.10.10.2/28
and made sure to ifconfig up all interfaces with no success.
