Lucas Rey
- Jul 25, 2011
Hello community, I have the following MoBo for my freenas installation:
https://www.asrock.com/MB/Intel/H370M-ITXac/index.asp#Manual
The 2 LAN ports are used in LACP (lagg0) and they work perfect. I enabled the WiFi onboard module from BIOS, but I can't get interface on system (see below).
I'm not FreeBSD expert, so please, any advice?
Thank you
Lucas
Thank you
Lucas
igb0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=b8<VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM> ether 70:85:c2:8c:d9:00 hwaddr 70:85:c2:8c:d9:02 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (1000baseT <full-duplex>) status: active em0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=98<VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM> ether 70:85:c2:8c:d9:00 hwaddr 70:85:c2:8c:d9:00 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (1000baseT <full-duplex>) status: active lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3 inet 127.0.0.1 netmask 0xff000000 nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> groups: lo tap0: flags=8942<BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 description: Attached to HA_VM_1 options=80000<LINKSTATE> ether 00:bd:b3:a9:f7:00 hwaddr 00:bd:b3:a9:f7:00 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect status: active groups: tap Opened by PID 3997 bridge0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 02:ab:72:e3:1e:00 nd6 options=9<PERFORMNUD,IFDISABLED> groups: bridge id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: tap0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 5 priority 128 path cost 2000000 lagg0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=98<VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM> ether 70:85:c2:8c:d9:00 inet 192.168.10.6 netmask 0xffffff00 broadcast 192.168.10.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect status: active groups: lagg laggproto lacp lagghash l2,l3,l4 laggport: igb0 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING> laggport: em0 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING>
