You can try plugging it back in and see what happens and post the "gpart show" again.
Just to confirm again, after you do that are you still getting the "Error getting used space" message?
(The post below boarders on TMI)
The error message persists. I have rebuilt the RAIDZ2 with all 6 drives now. The previous was exported with the destroy data box checked. Your initial two requests are posted. Will, I attached the dmesg in the last section of this post. At the bottom of the dmesg is an error about drive geometry.
At this point I am really beginning to wonder if I need a new motherboard or drives or whatnot. I'm good going to update hardware but I just don't want to spin out again.
Pre Reboot: All 6 drives are in a zraid2. GUI shows that the vol is healthy at 7.1 TiB.
[root@freenas] ~# sqlite3 /data/freenas-v1.db "select * from storage_disk;"
Disabled|Always On|{uuid}a22a5e51-58ce-11e1-aa34-0016178e327b|1|Disabled|Auto|Member of zraid2test raidz2|1||1|ada0
Disabled|Always On|{uuid}a2b87a48-58ce-11e1-aa34-0016178e327b|1|Disabled|Auto|Member of zraid2test raidz2|1||2|ada1
Disabled|Always On|{uuid}a33cd74d-58ce-11e1-aa34-0016178e327b|1|Disabled|Auto|Member of zraid2test raidz2|1||3|ada2
Disabled|Always On|{uuid}a3cde9b0-58ce-11e1-aa34-0016178e327b|1|Disabled|Auto|Member of zraid2test raidz2|1||4|ada3
Disabled|Always On|{uuid}a45884f8-58ce-11e1-aa34-0016178e327b|1|Disabled|Auto|Member of zraid2test raidz2|1||5|ada4
Disabled|Always On|{uuid}a4e9021d-58ce-11e1-aa34-0016178e327b|1|Disabled|Auto|Member of zraid2test raidz2|1||6|ada5
[root@freenas] ~# sqlite3 /data/freenas-v1.db "select * from storage_diskgroup;"
1|zraid2testraidz2|raidz2|1
[root@freenas] ~# gpart show
=> 63 7896987 da0 MBR (3.8G)
63 1930257 1 freebsd [active] (943M)
1930320 63 - free - (32K)
1930383 1930257 2 freebsd (943M)
3860640 3024 3 freebsd (1.5M)
3863664 41328 4 freebsd (20M)
3904992 3992058 - free - (1.9G)
=> 0 1930257 da0s1 BSD (943M)
0 16 - free - (8.0K)
16 1930241 1 !0 (943M)
=> 34 3907029101 ada0 GPT (1.8T)
34 94 - free - (47K)
128 4194304 1 freebsd-swap (2.0G)
4194432 3902834703 2 freebsd-zfs (1.8T)
=> 34 3907029101 ada1 GPT (1.8T)
=> 34 3907029101 ada2 GPT (1.8T)
=> 34 3907029101 ada3 GPT (1.8T)
=> 34 3907029101 ada4 GPT (1.8T)
=> 34 3907029101 ada5 GPT (1.8T)
After: errors abound getting total and available space.
[root@freenas] ~# dmesg
Copyright (c) 1992-2011 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 8.2-RELEASE-p6 #0: Wed Jan 18 13:52:11 PST 2012
root@build.ixsystems.com:/build/home/gcooper/e2e-bld.Pp7kV0qa/obj.amd64/build/home/gcooper/e2e-bld.Pp7kV0qa/FreeBSD/src/sys/FREENAS.amd64 amd64
Timecounter "i8254" frequency 1193182 Hz quality 0
CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 4600+ (2400.01-MHz K8-class CPU)
Origin = "AuthenticAMD" Id = 0x40fb2 Family = f Model = 4b Stepping = 2
Features=0x178bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2,HTT>
Features2=0x2001<SSE3,CX16>
AMD Features=0xea500800<SYSCALL,NX,MMX+,FFXSR,RDTSCP,LM,3DNow!+,3DNow!>
AMD Features2=0x1f<LAHF,CMP,SVM,ExtAPIC,CR8>
real memory = 8589934592 (8192 MB)
avail memory = 8245153792 (7863 MB)
ACPI APIC Table: <MSIISM OEMAPIC >
FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs
FreeBSD/SMP: 1 package(s) x 2 core(s)
cpu0 (BSP): APIC ID: 0
cpu1 (AP): APIC ID: 1
ioapic0 <Version 1.1> irqs 0-23 on motherboard
kbd1 at kbdmux0
cryptosoft0: <software crypto> on motherboard
acpi0: <MSIISM OEMRSDT> on motherboard
acpi0: [ITHREAD]
acpi0: Power Button (fixed)
acpi0: reservation of fec00000, 1000 (3) failed
acpi0: reservation of fee00000, 1000 (3) failed
acpi0: reservation of 0, a0000 (3) failed
acpi0: reservation of 100000, cff00000 (3) failed
Timecounter "ACPI-fast" frequency 3579545 Hz quality 1000
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x2008-0x200b on acpi0
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pci0: <memory, RAM> at device 0.0 (no driver attached)
isab0: <PCI-ISA bridge> port 0x2f00-0x2f7f at device 1.0 on pci0
isa0: <ISA bus> on isab0
pci0: <serial bus, SMBus> at device 1.1 (no driver attached)
ohci0: <nVidia nForce MCP55 USB Controller> mem 0xfcffb000-0xfcffbfff irq 22 at device 2.0 on pci0
ohci0: [ITHREAD]
usbus0: <nVidia nForce MCP55 USB Controller> on ohci0
ehci0: <NVIDIA nForce MCP55 USB 2.0 controller> mem 0xfcffac00-0xfcffacff irq 23 at device 2.1 on pci0
ehci0: [ITHREAD]
usbus1: EHCI version 1.0
usbus1: <NVIDIA nForce MCP55 USB 2.0 controller> on ehci0
atapci0: <nVidia nForce MCP55 SATA300 controller> port 0xb480-0xb487,0xb400-0xb403,0xb080-0xb087,0xb000-0xb003,0xac00-0xac0f mem 0xfcff9000-0xfcff9fff irq 21 at device 5.0 on pci0
atapci0: [ITHREAD]
ata2: <ATA channel 0> on atapci0
ata2: [ITHREAD]
ata3: <ATA channel 1> on atapci0
ata3: [ITHREAD]
atapci1: <nVidia nForce MCP55 SATA300 controller> port 0xa880-0xa887,0xa800-0xa803,0xa480-0xa487,0xa400-0xa403,0xa080-0xa08f mem 0xfcff8000-0xfcff8fff irq 22 at device 5.1 on pci0
atapci1: [ITHREAD]
ata4: <ATA channel 0> on atapci1
ata4: [ITHREAD]
ata5: <ATA channel 1> on atapci1
ata5: [ITHREAD]
atapci2: <nVidia nForce MCP55 SATA300 controller> port 0xa000-0xa007,0x9c00-0x9c03,0x9880-0x9887,0x9800-0x9803,0x9480-0x948f mem 0xfcff7000-0xfcff7fff irq 23 at device 5.2 on pci0
atapci2: [ITHREAD]
ata6: <ATA channel 0> on atapci2
ata6: [ITHREAD]
ata7: <ATA channel 1> on atapci2
ata7: [ITHREAD]
pcib1: <ACPI PCI-PCI bridge> at device 6.0 on pci0
pci1: <ACPI PCI bus> on pcib1
vgapci0: <VGA-compatible display> port 0xc000-0xc0ff mem 0xfd000000-0xfdffffff,0xfeaff000-0xfeafffff irq 16 at device 0.0 on pci1
pci0: <multimedia, HDA> at device 6.1 (no driver attached)
nfe0: <NVIDIA nForce MCP55 Networking Adapter> port 0x9400-0x9407 mem 0xfcff6000-0xfcff6fff,0xfcffa800-0xfcffa8ff,0xfcffa400-0xfcffa40f irq 20 at device 8.0 on pci0
miibus0: <MII bus> on nfe0
ciphy0: <Vitesse VSC8601 10/100/1000TX PHY> PHY 0 on miibus0
ciphy0: 10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX, 100baseTX-FDX, 100baseTX-FDX-flow, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, 1000baseT-FDX-flow, 1000baseT-FDX-flow-master, auto, auto-flow
nfe0: Ethernet address: 00:16:17:8e:32:7b
nfe0: [FILTER]
nfe0: [FILTER]
nfe0: [FILTER]
nfe0: [FILTER]
nfe0: [FILTER]
nfe0: [FILTER]
nfe0: [FILTER]
nfe0: [FILTER]
nfe1: <NVIDIA nForce MCP55 Networking Adapter> port 0x9080-0x9087 mem 0xfcff5000-0xfcff5fff,0xfcffa000-0xfcffa0ff,0xfcff4c00-0xfcff4c0f irq 20 at device 9.0 on pci0
miibus1: <MII bus> on nfe1
ciphy1: <Vitesse VSC8601 10/100/1000TX PHY> PHY 1 on miibus1
ciphy1: 10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX, 100baseTX-FDX, 100baseTX-FDX-flow, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, 1000baseT-FDX-flow, 1000baseT-FDX-flow-master, auto, auto-flow
nfe1: Ethernet address: 00:16:17:78:e8:66
nfe1: [FILTER]
nfe1: [FILTER]
nfe1: [FILTER]
nfe1: [FILTER]
nfe1: [FILTER]
nfe1: [FILTER]
nfe1: [FILTER]
nfe1: [FILTER]
pcib2: <ACPI PCI-PCI bridge> at device 11.0 on pci0
pci2: <ACPI PCI bus> on pcib2
pcib3: <ACPI PCI-PCI bridge> at device 12.0 on pci0
pci3: <ACPI PCI bus> on pcib3
pcib4: <ACPI PCI-PCI bridge> at device 13.0 on pci0
pci4: <ACPI PCI bus> on pcib4
ahci0: <Marvell 88SE912x AHCI SATA controller> port 0xec00-0xec07,0xe880-0xe883,0xe800-0xe807,0xe480-0xe483,0xe400-0xe40f mem 0xfebff800-0xfebfffff irq 17 at device 0.0 on pci4
ahci0: [ITHREAD]
ahci0: AHCI v1.20 with 8 6Gbps ports, Port Multiplier not supported
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich0: [ITHREAD]
ahcich1: <AHCI channel> at channel 1 on ahci0
ahcich1: [ITHREAD]
ahcich2: <AHCI channel> at channel 2 on ahci0
ahcich2: [ITHREAD]
ahcich3: <AHCI channel> at channel 3 on ahci0
ahcich3: [ITHREAD]
ahcich4: <AHCI channel> at channel 4 on ahci0
ahcich4: [ITHREAD]
ahcich5: <AHCI channel> at channel 5 on ahci0
ahcich5: [ITHREAD]
ahcich6: <AHCI channel> at channel 6 on ahci0
ahcich6: [ITHREAD]
ahcich7: <AHCI channel> at channel 7 on ahci0
ahcich7: [ITHREAD]
atapci3: <Marvell 88SE912x UDMA133 controller> port 0xe080-0xe087,0xe000-0xe003,0xdc00-0xdc07,0xd880-0xd883,0xd800-0xd80f mem 0xfebff400-0xfebff40f irq 18 at device 0.1 on pci4
pcib5: <ACPI PCI-PCI bridge> at device 14.0 on pci0
pci5: <ACPI PCI bus> on pcib5
pcib6: <ACPI PCI-PCI bridge> at device 15.0 on pci0
pci6: <ACPI PCI bus> on pcib6
amdtemp0: <AMD K8 Thermal Sensors> on hostb3
acpi_button0: <Power Button> on acpi0
atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
uart0: [FILTER]
acpi_hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed00fff on acpi0
Timecounter "HPET" frequency 25000000 Hz quality 900
atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
atkbd0: [ITHREAD]
orm0: <ISA Option ROM> at iomem 0xc0000-0xc7fff on isa0
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
ppc0: cannot reserve I/O port range
powernow0: <PowerNow! K8> on cpu0
device_attach: powernow0 attach returned 6
powernow1: <PowerNow! K8> on cpu1
device_attach: powernow1 attach returned 6
fuse4bsd: version 0.3.9-pre1, FUSE ABI 7.8
Timecounters tick every 1.000 msec
usbus0: 12Mbps Full Speed USB v1.0
usbus1: 480Mbps High Speed USB v2.0
ugen0.1: <nVidia> at usbus0
uhub0: <nVidia OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
ugen1.1: <nVidia> at usbus1
uhub1: <nVidia EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
uhub0: 10 ports with 10 removable, self powered
uhub1: 10 ports with 10 removable, self powered
ugen0.2: <DELL> at usbus0
ukbd0: <DELL DELL USB Keyboard, class 0/0, rev 1.10/1.05, addr 2> on usbus0
kbd2 at ukbd0
ugen1.2: <USB 2.0> at usbus1
umass0: <USB 2.0 USB Flash Drive, class 0/0, rev 2.00/1.00, addr 2> on usbus1
ada0 at ata2 bus 0 scbus0 target 0 lun 0
ada0: <ST2000DL003-9VT166 CC32> ATA-8 SATA 3.x device
ada0: 300.000MB/s transfers (SATA 2.x, UDMA5, PIO 8192bytes)
ada0: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada1 at ata3 bus 0 scbus1 target 0 lun 0
ada1: <ST2000DL003-9VT166 CC32> ATA-8 SATA 3.x device
ada1: 300.000MB/s transfers (SATA 2.x, UDMA5, PIO 8192bytes)
ada1: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
da0 at umass-sim0 bus 0 scbus14 target 0 lun 0
da0: <USB 2.0 USB Flash Drive 0.00> Removable Direct Access SCSI-2 device
da0: 40.000MB/s transfers
da0: 3856MB (7897088 512 byte sectors: 255H 63S/T 491C)
ada2 at ata4 bus 0 scbus2 target 0 lun 0
ada2: <ST2000DL003-9VT166 CC3C> ATA-8 SATA 3.x device
ada2: 300.000MB/s transfers (SATA 2.x, UDMA5, PIO 8192bytes)
ada2: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada3 at ata5 bus 0 scbus3 target 0 lun 0
ada3: <ST2000DL003-9VT166 CC32> ATA-8 SATA 3.x device
ada3: 300.000MB/s transfers (SATA 2.x, UDMA5, PIO 8192bytes)
ada3: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada4 at ata6 bus 0 scbus4 target 0 lun 0
ada4: <ST2000DL003-9VT166 CC32> ATA-8 SATA 3.x device
ada4: 300.000MB/s transfers (SATA 2.x, UDMA5, PIO 8192bytes)
ada4: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada5 at ata7 bus 0 scbus5 target 0 lun 0
ada5: <ST2000DL003-9VT166 CC32> ATA-8 SATA 3.x device
ada5: 150.000MB/s transfers (SATA 1.x, UDMA5, PIO 8192bytes)
ada5: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
pass6 at ahcich7 bus 0 scbus13 target 0 lun 0
pass6: <Marvell 91xx Config 1.01> Removable Processor SCSI-0 device
pass6: 150.000MB/s transfers (SATA 1.x, UDMA4, ATAPI 12bytes, PIO 8192bytes)
SMP: AP CPU #1 Launched!
GEOM: da0s1: geometry does not match label (16h,63s != 255h,63s).
Trying to mount root from ufs:/dev/ufs/FreeNASs1a
ZFS filesystem version 4
ZFS storage pool version 15
