ZFS scrub stuck, and won't continue
ChipKng
I google'd a lot but cannot find any solution to my problem:
The ZFS scrubbing stuck at 56.66% and does not continue:
root@freenas:~ # zpool status -v Prim
  pool: Prim
 state: ONLINE
status: Some supported features are not enabled on the pool. The pool can
		still be used, but some features are unavailable.
  scan: scrub in progress since Sun Dec 24 00:00:03 2017
		3.72T scanned at 922K/s, 3.62T issued at 0/s, 6.38T total
		0 repaired, 56.66% done, no estimated completion time
		NAME										  STATE	 READ WRITE CKSUM
		Prim										  ONLINE	   0	 0	 0
		  gptid/848a2c20-462d-11e2-a28f-009c02abd968  ONLINE	   0	 0	 0
		  gptid/46c3259e-46d4-11e2-ae03-009c02abd968  ONLINE	   0	 0	 0
		  gptid/7432c6a3-51a4-11e2-9357-009c02abd968  ONLINE	   0	 0	 0
		  gptid/4ce2c4c0-4e33-11e3-b6c9-009c02abd968  ONLINE	   0	 0	 0
errors: No known data errors
When I try to stop it from command line, it does not do anything and the prompt does not come back. When I try to delete anything from that pool, it removes the file, but the prompt does not come back and the space is not freed up.
Anybody can help? What can I do? I tried rebooting the system: the system won't shut down. It stuck, I have to use the power switch.
Any suggestion are welcome. Thanks in advance!
edit: I'm using Freenas 11.1-RELEASE version.
rs225
This seems to be a bug. Moving back to a prior version of FreeNAS is the solution at the moment.
ChipKng
Seems this option will not work as well:
Request Method: 	 POST
	 Request URL: 	 http://192.168.1.200/system/bootenv/activate/11.0-U4/
	 Software Version: 	 FreeNAS-11.1-RELEASE (dc7d195f4)
	 Exception Type: 	 CallTimeout
	 Exception Value:
Call timeout
	 Exception Location: 	 /usr/local/lib/python3.6/site-packages/middlewared/client/client.py in call, line 389
	 Server time: 	 Fri, 29 Dec 2017 21:13:24 +0100
rs225
If you have console access, you should be able to select the different boot environment from the boot loader menu.
You also moved back to prior version?
Yes, and it's working fine on 11.0-U4. As @rs225 says, you can pick the former boot environment from the boot loader menu. Once that's started, you can set it to reboot to that one through the web GUI.
ChipKng
Hi guys, thanks for the tips. I had to hook up a monitor to go into the boot environment, and going back to 11.0-U4 the scrubbing continues. I don't know why am I did not think about this option... maybe too lazy...
Anyway, thanks for the help!
Stuck at 56%... That's a new one. File a bug report for this, please. I tried to find some of the existing ones, but couldn't, so they're probably all private.
rs225
I think I saw a bug report yesterday that seems to have the scrub problem identified. It was already 7 days old. The devs already had a suspect in the code.
ChipKng
Do you mean this one?
Please confirm if I should open a new bug report, or it's covering my problem as well.
Thanks!
rs225
That is the one. It is up to you whether you think a new bug should be filed, or it might be possible for you to comment on that one if you have anything to add.
petr
Same experience, only I seems to be stuck on 62.65%.
Was anyone able to fix this issue without downgrading? Running FreeNAS-11.1-U5.
Only got the issue with one volume that is connected to the same SAS backplane as other disks (all sata disks)
Tried re-running but now stuck at zero. Everything else seems to be working fine.
Unless you're running one of those old versions, which you're not, your problem is a different one.
Please open a new thread and explain your setup in detail. Also, check the SMART data for the disks, because one or more of them are likely on their way out.
petr
