petr
- Jun 13, 2013
I cannot seem to be able to complete a scrub on one of my volumes. I have noticed it being stuck on 62.65% for a very long time (20+ days), so I've stopped the scrub (which went OK albeit took 30s) and rebooted the machine. Then, started the scrub again and it got to 62.65% pretty fast (as fast as expected) but then did not move any further.
Restarting the scrub again yielded a zero progress which does not move:
No errors are reported, all SMART info shows "PASSED" and the system is performing just fine (data access via NFS and AFP, jails).
Details of my config are in signature - the volume in question is the 7x8TB WD drives connected to a backplane that is shared between all my drives.
Please see below what the status says after the stopping and re-running. Also a bit confused by the "issued at"
Running FreeNAS-11.1-U5 with all available updates applied.
EDIT: Further information:
- Hypervisor - VMWare ESXI
- 24GB RAM available
- all storage hardware (M1015) is pass-through directly to the VM
(The setup is now new, have been running FreeNAS like this since 2012)
root@freenas:~ # zpool status mainsafe pool: mainsafe state: ONLINE status: Some supported features are not enabled on the pool. The pool can still be used, but some features are unavailable. action: Enable all features using 'zpool upgrade'. Once this is done, the pool may no longer be accessible by software that does not support the features. See zpool-features(7) for details. scan: scrub in progress since Wed Jun 27 14:25:46 2018 0 scanned at 0/s, 0 issued at 0/s, 25.2T total 0 repaired, 0.00% done, no estimated completion time config: NAME STATE READ WRITE CKSUM mainsafe ONLINE 0 0 0 raidz3-0 ONLINE 0 0 0 gptid/a4b8bb14-17d7-11e8-a2dd-000c293a32fe ONLINE 0 0 0 gptid/a5859ce3-17d7-11e8-a2dd-000c293a32fe ONLINE 0 0 0 gptid/a647bcbb-17d7-11e8-a2dd-000c293a32fe ONLINE 0 0 0 gptid/a70459ab-17d7-11e8-a2dd-000c293a32fe ONLINE 0 0 0 gptid/a7c75791-17d7-11e8-a2dd-000c293a32fe ONLINE 0 0 0 gptid/a88e1cd5-17d7-11e8-a2dd-000c293a32fe ONLINE 0 0 0 gptid/a94e05d1-17d7-11e8-a2dd-000c293a32fe ONLINE 0 0 0
