Hi Everyone
I recently got my server back online (was remodeling and server room was being built). The specs are below. I immediately ran a scrub. I got an email the next morning saying:
"The volume Volume01 state is ONLINE: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected."
So here is the pool status from right after the finished scrub .
I then ran Short and long tests of the offending drive. No values were sticking out to me and both tests came back complete without errors.
So I cleared the zpool status and reran the scrub this morning. No Checksum errors.
So is this just ZFS doing it's thing and fixing corrupt data or is there something going on in my system? Should I do a Memory Test?
System Specs
Motherboard: X8DTi-F
Backplane: SAS2 6Gb/s Expander Backplane
Dual E5640L
96GB EEC DDR3 RAM
LSI 9210-8i HBA
Raidz-0 is made up of 8TB Seagate Drives. Issue was on DA05
Raidz-1 is 3TB HGST NAS Drives
Raidz-2 is a mix of 8TB HGST and 8TB Seagate Drives.
Thanks for your help and time.
NAME STATE READ WRITE CKSUM
Volume01 ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/160ad1b3-f744-11e8-a544-00259080c872 ONLINE 0 0 0
gptid/17372117-f744-11e8-a544-00259080c872 ONLINE 0 0 0
gptid/18641503-f744-11e8-a544-00259080c872 ONLINE 0 0 0
gptid/19acedda-f744-11e8-a544-00259080c872 ONLINE 0 0 0
gptid/1aeff334-f744-11e8-a544-00259080c872 ONLINE 0 0 9 (repairing)
gptid/1c1c5da9-f744-11e8-a544-00259080c872 ONLINE 0 0 0
raidz2-1 ONLINE 0 0 0
gptid/1d7d57ee-f744-11e8-a544-00259080c872 ONLINE 0 0 0
gptid/20b12a00-f744-11e8-a544-00259080c872 ONLINE 0 0 0
gptid/23955ed6-f744-11e8-a544-00259080c872 ONLINE 0 0 0
gptid/265a01d2-f744-11e8-a544-00259080c872 ONLINE 0 0 0
gptid/294c255b-f744-11e8-a544-00259080c872 ONLINE 0 0 0
gptid/2cf4b9bc-f744-11e8-a544-00259080c872 ONLINE 0 0 0
raidz2-2 ONLINE 0 0 0
gptid/e8dc4451-f89f-11e8-965b-00259080c872 ONLINE 0 0 0
gptid/ea344686-f89f-11e8-965b-00259080c872 ONLINE 0 0 0
gptid/eb1bc349-f89f-11e8-965b-00259080c872 ONLINE 0 0 0
gptid/ec702641-f89f-11e8-965b-00259080c872 ONLINE 0 0 0
gptid/edb8b034-f89f-11e8-965b-00259080c872 ONLINE 0 0 0
gptid/eef56ec8-f89f-11e8-965b-00259080c872 ONLINE 0 0 0
errors: No known data errors
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model: ST8000DM004-2CX188
Serial Number: WCT0QXF5
LU WWN Device Id: 5 000c50 0ba1b6cec
Firmware Version: 0001
User Capacity: 8,001,563,222,016 bytes [8.00 TB]
Rotation Rate: 5425 rpm
Form Factor: 3.5 inches
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Feb 4 12:20:57 2019 EST
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: ( 0) seconds.
capabilities: (0x73) SMART execute Offline immediate.
command.
No Offline surface scan supported.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 975) minutes.
Conveyance self-test routine
SCT capabilities: (0x30a5) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 076 064 006 Pre-fail Always - 37804480
3 Spin_Up_Time 0x0003 093 091 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 31
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 077 061 045 Pre-fail Always - 47955113
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 284 (211 239 0)
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 31
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 073 047 040 Old_age Always - 27 (Min/Max 15/33)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 31
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 64
194 Temperature_Celsius 0x0022 027 053 000 Old_age Always - 27 (0 15 0 0 0)
195 Hardware_ECC_Recovered 0x001a 076 064 000 Old_age Always - 37804480
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 229 (161 129 0)
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 60690732973
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 71821424672
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed without error 00% 274 -
# 2 Short offline Completed without error 00% 259 -
# 3 Short offline Completed without error 00% 181 -
# 4 Conveyance offline Completed without error 00% 160 -
# 5 Short offline Completed without error 00% 160 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay.So I cleared the zpool status and reran the scrub this morning. No Checksum errors.
pool: Volume01
state: ONLINE
scan: scrub repaired 0 in 0 days 04:58:11 with 0 errors on Mon Feb 4 12:34:24 2019
gptid/1aeff334-f744-11e8-a544-00259080c872 ONLINE 0 0 0
errors: No known data errorsSo is this just ZFS doing it's thing and fixing corrupt data or is there something going on in my system? Should I do a Memory Test?
System Specs
Dual E5640L
96GB EEC DDR3 RAM
LSI 9210-8i HBA
