ZFS from OpenMediaVault to FreeNas
christophe195
I did have a ZFS pool of 3 HDD (3X3TB => 4TB usable) on a openmediavault install but after some boot problems i had decide to go to freenas. I have a fresh install of the system and the drives are spinning but i have no idea how i can rebuild everything off the drives.
Can someone guide me trough the process?
Greathings Christophe VD
christophe195
What do you get at the CLI from zpool import ?
Yorick
Yup, right there. userobj_accounting isn't in FreeNAS 11.3. It is in the current nightly of TrueNAS Core 12.0. TrueNAS Core isn't ready, it'll go into Alpha MoreSoonerish(tm), and then be released sometime 2020.
You can import this pool readonly from command line, but that doesn't do anything for you. You can take the data off to an external drive, the 6 and 8TB ones are cheap. Then rebuild the pool, and restore the data.
