ZFS Drive failure
KevDog
Hi I'm running an eight disk zfs z2 array with one hot spare. I was notified by the system of a drive failure.
I just want to make sure I'm interpreting results accurately. I believe the offending drive is da5:
pool: tank
 state: ONLINE
status: One or more devices has experienced an unrecoverable error.  An
    attempt was made to correct the error.  Applications are unaffected.
   see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-9P
  scan: resilvered 16.8G in 00:22:23 with 0 errors on Fri Sep  2 08:50:42 2022
    NAME                                              STATE     READ WRITE CKSUM
    tank                                              ONLINE       0     0     0
      raidz2-0                                        ONLINE       0     0     0
        gptid/16f8514f-6a3d-11ea-83c6-0cc47a84a594    ONLINE       0     0     0
        gptid/2eff3431-d2f0-11e6-8e60-0cc47a84a594    ONLINE       0     0     0
        gptid/2fad6079-d2f0-11e6-8e60-0cc47a84a594    ONLINE       0     0     0
        gptid/96f13243-a9e5-11ea-ab76-0cc47a84a594    ONLINE       0     0     0
        gptid/310fd248-d2f0-11e6-8e60-0cc47a84a594    ONLINE       0     0     0
        spare-5                                       ONLINE       0     0     0
          gptid/31c62952-d2f0-11e6-8e60-0cc47a84a594  ONLINE       0     1     0
          gptid/a203d5ad-49e3-11ea-9739-0cc47a84a594  ONLINE       0     0     0
        gptid/32845d1c-d2f0-11e6-8e60-0cc47a84a594    ONLINE       0     0     0
        gptid/3338ea10-d2f0-11e6-8e60-0cc47a84a594    ONLINE       0     0     0
    cache
      gptid/752998f6-094f-11ec-9a66-0cc47a84a594      ONLINE       0     0     0
    spares
      gptid/a203d5ad-49e3-11ea-9739-0cc47a84a594      INUSE     currently in use
errors: No known data errors
# glabel status
                                      Name  Status  Components
gptid/622dd1d9-cdae-11e6-be8a-0cc47a84a594     N/A  ada0p1
gptid/0df883e1-d080-11e6-8e60-0cc47a84a594     N/A  ada1p1
gptid/a203d5ad-49e3-11ea-9739-0cc47a84a594     N/A  ada3p2
gptid/752998f6-094f-11ec-9a66-0cc47a84a594     N/A  ada2p1
gptid/16f8514f-6a3d-11ea-83c6-0cc47a84a594     N/A  da0p2
gptid/96f13243-a9e5-11ea-ab76-0cc47a84a594     N/A  da3p2
gptid/310fd248-d2f0-11e6-8e60-0cc47a84a594     N/A  da4p2
gptid/2fad6079-d2f0-11e6-8e60-0cc47a84a594     N/A  da2p2
gptid/2eff3431-d2f0-11e6-8e60-0cc47a84a594     N/A  da1p2
gptid/31c62952-d2f0-11e6-8e60-0cc47a84a594     N/A  da5p2
gptid/3338ea10-d2f0-11e6-8e60-0cc47a84a594     N/A  da7p2
gptid/32845d1c-d2f0-11e6-8e60-0cc47a84a594     N/A  da6p2
#sas3ircu 0 DISPLAY
Device is a Hard disk
  Enclosure #                             : 1
  Slot #                                  : 5
  SAS Address                             : 4433221-1-0500-0000
  State                                   : Ready (RDY)
  Size (in MB)/(in sectors)               : 5723166/11721045167
  Manufacturer                            : ATA
  Model Number                            : WDC WD60EFRX-68L
  Firmware Revision                       : 0A82
  Serial No                               : WDWXL1H16RYYAK
  Unit Serial No(VPD)                     : WD-WXL1H16RYYAK
  GUID                                    : N/A
  Protocol                                : SATA
  Drive Type                              : SATA_HDD
I believe the gptid 31c62952-d2f0-11e6-8e60-0cc47a84a594/da5 is experiencing a write failure as per the table? and then the spare was activated to take over. I'm performing a smartctl long test on the offending drive at the moment. Nothing showed up on the short smtctl test of the drive. I just wanted to ensure I'm interpreting results correctly.
KevDog
So running the smartctl long test I do indeed get a read failure:
# 1  Extended offline    Completed: read failure       10%     46393         2889891760
# 2  Extended offline    Interrupted (host reset)      50%     46378         -
# 3  Short captive       Interrupted (host reset)      90%     46372         -
# 4  Short captive       Interrupted (host reset)      90%     46372         -
# 5  Short offline       Completed without error       00%     46372         -
# 6  Short offline       Completed without error       00%     46314         -
# 7  Short offline       Completed without error       00%     46146         -
# 8  Short offline       Completed without error       00%     45978         -
# 9  Short offline       Completed without error       00%     45810         -
#10  Short offline       Completed without error       00%     45642         -
#11  Short offline       Completed without error       00%     45474         -
#12  Short offline       Completed without error       00%     45307         -
#13  Short offline       Completed without error       00%     45139         -
#14  Short offline       Completed without error       00%     44975         -
#15  Short offline       Completed without error       00%     44807         -
#16  Short offline       Completed without error       00%     44639         -
#17  Short offline       Completed without error       00%     44471         -
#18  Short offline       Completed without error       00%     44303         -
#19  Short offline       Completed without error       00%     44136         -
#20  Short offline       Completed without error       00%     43968         -
#21  Short offline       Completed without error       00%     43800         -
So my question is -- is this part of a failing drive (probably) or is this just something for example I could reformat the drive and then let zfs rebuild the array?
Samuel Tai
Your drive is failing. The zpool status shows a checksum mismatch during a write, and SMART shows a read failure during a self-test. Please run the replacement procedure with a new, burned-in drive.
KevDog
Hey thanks.
