Hi I'm running an eight disk zfs z2 array with one hot spare. I was notified by the system of a drive failure.
I just want to make sure I'm interpreting results accurately. I believe the offending drive is da5:
I believe the gptid 31c62952-d2f0-11e6-8e60-0cc47a84a594/da5 is experiencing a write failure as per the table? and then the spare was activated to take over. I'm performing a smartctl long test on the offending drive at the moment. Nothing showed up on the short smtctl test of the drive. I just wanted to ensure I'm interpreting results correctly.
pool: tank state: ONLINE status: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected. action: Determine if the device needs to be replaced, and clear the errors using 'zpool clear' or replace the device with 'zpool replace'. see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-9P scan: resilvered 16.8G in 00:22:23 with 0 errors on Fri Sep 2 08:50:42 2022 config: NAME STATE READ WRITE CKSUM tank ONLINE 0 0 0 raidz2-0 ONLINE 0 0 0 gptid/16f8514f-6a3d-11ea-83c6-0cc47a84a594 ONLINE 0 0 0 gptid/2eff3431-d2f0-11e6-8e60-0cc47a84a594 ONLINE 0 0 0 gptid/2fad6079-d2f0-11e6-8e60-0cc47a84a594 ONLINE 0 0 0 gptid/96f13243-a9e5-11ea-ab76-0cc47a84a594 ONLINE 0 0 0 gptid/310fd248-d2f0-11e6-8e60-0cc47a84a594 ONLINE 0 0 0 spare-5 ONLINE 0 0 0 gptid/31c62952-d2f0-11e6-8e60-0cc47a84a594 ONLINE 0 1 0 gptid/a203d5ad-49e3-11ea-9739-0cc47a84a594 ONLINE 0 0 0 gptid/32845d1c-d2f0-11e6-8e60-0cc47a84a594 ONLINE 0 0 0 gptid/3338ea10-d2f0-11e6-8e60-0cc47a84a594 ONLINE 0 0 0 cache gptid/752998f6-094f-11ec-9a66-0cc47a84a594 ONLINE 0 0 0 spares gptid/a203d5ad-49e3-11ea-9739-0cc47a84a594 INUSE currently in use errors: No known data errors
# glabel status Name Status Components gptid/622dd1d9-cdae-11e6-be8a-0cc47a84a594 N/A ada0p1 gptid/0df883e1-d080-11e6-8e60-0cc47a84a594 N/A ada1p1 gptid/a203d5ad-49e3-11ea-9739-0cc47a84a594 N/A ada3p2 gptid/752998f6-094f-11ec-9a66-0cc47a84a594 N/A ada2p1 gptid/16f8514f-6a3d-11ea-83c6-0cc47a84a594 N/A da0p2 gptid/96f13243-a9e5-11ea-ab76-0cc47a84a594 N/A da3p2 gptid/310fd248-d2f0-11e6-8e60-0cc47a84a594 N/A da4p2 gptid/2fad6079-d2f0-11e6-8e60-0cc47a84a594 N/A da2p2 gptid/2eff3431-d2f0-11e6-8e60-0cc47a84a594 N/A da1p2 gptid/31c62952-d2f0-11e6-8e60-0cc47a84a594 N/A da5p2 gptid/3338ea10-d2f0-11e6-8e60-0cc47a84a594 N/A da7p2 gptid/32845d1c-d2f0-11e6-8e60-0cc47a84a594 N/A da6p2
#sas3ircu 0 DISPLAY ... ... Device is a Hard disk Enclosure # : 1 Slot # : 5 SAS Address : 4433221-1-0500-0000 State : Ready (RDY) Size (in MB)/(in sectors) : 5723166/11721045167 Manufacturer : ATA Model Number : WDC WD60EFRX-68L Firmware Revision : 0A82 Serial No : WDWXL1H16RYYAK Unit Serial No(VPD) : WD-WXL1H16RYYAK GUID : N/A Protocol : SATA Drive Type : SATA_HDD ... ...
