Ok I'll answer my own question. I'll first put this post as a reference since it really helped despite the very humorous tone of the discussion:
https://www.ixsystems.com/community...gptid-instead-of-da1p2-in-zpool-status.18441/
GPTIDs are something internal to Freenas -- or to simplify -- FreeNAS adds them. So basically you need to do everything through the GUI and not the CLI or the FreeNAS middleware will not be aware.
So specifically for the GUI
Storage->Pools->Extend
The Empty Drive should be listed Under Available Disk
Push the button at the bottom and select Add Spare.
Now the really confusing part in the GUI is you want to add the available drive to only the Spare VDev. and not the DataVDev.
So In order to do this you'll need to mess around with hitting the blue arrows and select the Left to Right for the Spare VDev and UNSELECT the Left to Right Arrow for the Data VDev.
Once you've gotten things setup, hit the Extend button at the bottom. There will be a warning about erasing the drive but keep the data in the original pool.
Once done:
# zpool status
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0 days 00:02:35 with 0 errors on Tue Feb 4 03:47:35 2020
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
ada0p2 ONLINE 0 0 0
ada1p2 ONLINE 0 0 0
errors: No known data errors
pool: tank
state: ONLINE
status: Some supported features are not enabled on the pool. The pool can
still be used, but some features are unavailable.
scan: scrub repaired 0 in 0 days 05:08:32 with 0 errors on Sun Feb 2 05:08:35 2020
tank ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/2e48e04a-d2f0-11e6-8e60-0cc47a84a594 ONLINE 0 0 0
gptid/2eff3431-d2f0-11e6-8e60-0cc47a84a594 ONLINE 0 0 0
gptid/2fad6079-d2f0-11e6-8e60-0cc47a84a594 ONLINE 0 0 0
gptid/305f9785-d2f0-11e6-8e60-0cc47a84a594 ONLINE 0 0 0
gptid/310fd248-d2f0-11e6-8e60-0cc47a84a594 ONLINE 0 0 0
gptid/31c62952-d2f0-11e6-8e60-0cc47a84a594 ONLINE 0 0 0
gptid/32845d1c-d2f0-11e6-8e60-0cc47a84a594 ONLINE 0 0 0
gptid/3338ea10-d2f0-11e6-8e60-0cc47a84a594 ONLINE 0 0 0
cache
gptid/3385f967-d2f0-11e6-8e60-0cc47a84a594 ONLINE 0 0 0
spares
gptid/a203d5ad-49e3-11ea-9739-0cc47a84a594 AVAIL
Now a couple of shoutouts for some scripts I found during the process. (I didn't create any of these scripts and do not support them, however I really found them useful when trying to hunt down devIDs, gptIDs, Serial Numbers of drives, etc.
The first is entitled lsblk.sh which gives output like the following:
The second I call serial_num_drive.sh which gives output similar to the following:
I list these here since they might help find out which drive in your case is associated with the devID (ie da0, etc).
#! /bin/sh
# Copyright (c) 2016-2019 Slawomir Wojciech Wojtczak (vermaden)
# All rights reserved.
# THIS SOFTWARE USES FREEBSD LICENSE (ALSO KNOWN AS 2-CLAUSE BSD LICENSE)
# https://www.freebsd.org/copyright/freebsd-license.html
# Redistribution and use in source and binary forms, with or without
# modification, are permitted provided that following conditions are met:
# 1. Redistributions of source code must retain the above copyright
# notice, this list of conditions and the following disclaimer.
# 2. Redistributions in binary form must reproduce the above copyright
# notice, this list of conditions and the following disclaimer in the
# documentation and/or other materials provided with the distribution.
# THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS 'AS IS' AND ANY
# EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
# WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
# DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE FOR ANY
# DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
# (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
# LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
# ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
# (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
# THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
# REPLACEMENT FOR LINUX lsblk(8)
# vermaden [AT] interia [DOT] pl
# https://vermaden.wordpress.com
PATH=${PATH}:/bin:/usr/bin:/usr/local/bin:/sbin:/usr/sbin:/usr/local/sbin
# DISPLAY HELP/USAGE/EXAMPLES
__usage() {
local NAME="${0##*/}"
cat << __EOF
usage:
BASIC USAGE INFORMATION
# ${NAME} [DISK]
example(s):
LIST ALL BLOCK DEVICES IN SYSTEM
# ${NAME}
DEVICE MAJ:MIN SIZE TYPE LABEL MOUNT
ada0 0:92 932G GPT - -
ada0p1 0:100 200M efi efiboot0 -
ada0p2 0:101 512K freebsd-boot gptboot0 -
<FREE> -:- 492K - - -
ada0p3 0:102 931G freebsd-zfs zfs0 <ZFS>
ada0p3.eli 0:106 931G freebsd-zfs - <ZFS>
LIST ONLY da1 BLOCK DEVICE
# ${NAME} da1
da1 0:80 2.0G MBR - -
da1s1 0:80 2.0G freebsd - -
da1s1a 0:81 1.0G freebsd-ufs root /
da1s1b 0:82 1.0G freebsd-swap swap SWAP
hint(s):
DISPLAY PHYSICAL DISKS
# sysctl kern.disks
kern.disks: ada0 da0 da1
DISPLAY MEMORY BACKED DISKS
# mdconfig -l
__EOF
exit 1
# __usage() ENDED
# GET MAJOR/MINOR NUMBERS
__major_minor() { # 1=DEV
local DEV=${1}
MAJ=$( stat -f "%Hr" /dev/${DEV} )
MIN=$( stat -f "%Lr" /dev/${DEV} )
# __major_minor() ENDED
# DETECT IF SWAP IS BEING USED
__swap_mount() { # 1=DEV
local DEV="${1}"
SWAP_FOUND=0
# DETECT SWAP BY RAW DEVICE
if swapctl -l | grep -q -- ${DEV} 2> /dev/null
then
TYPE=freebsd-swap
MOUNT=SWAP
LABEL="-"
SWAP_FOUND=1
return
fi
# DETECT SWAP BY LABEL
while read LABELER GARBAGE PROVIDER
do
if [ "${DEV}" = "${PROVIDER}" ]
then
if swapctl -l | grep -q -- ${LABELER} 2> /dev/null
then
TYPE=freebsd-swap
LABEL=${LABELER}
MOUNT=SWAP
SWAP_FOUND=1
break
fi
fi
done << __EOF
$( echo "${GLABEL}" )
__EOF
# __swap_mount() ENDED
# DETECT TYPE WITH fstyp(8) TOOL
__type() { # 1=DEV
local DEV=${1}
TYPE=$( fstyp -u /dev/${DEV} 2> /dev/null )
[ "${TYPE}" = "" ] && __swap_mount ${DEV}
[ "${TYPE}" = "" ] && TYPE="-"
# __type() ENDED
# DETECT MOUNT/LABEL IF POSSIBLE
__mount_label() { # 1=TARGET
local TARGET="${1}"
local MOUNT_FOUND=0
local LABEL_FOUND=0
LABEL="-"
if [ "${SWAP_FOUND}" = "1" ]
then
local MOUNT_FOUND=1
else
MOUNT="-"
fi
# CHECK IF DEVICE EXISTS
[ ! -e /dev/${TARGET} ] && return
# TRY CLASSIC MOUNT POINT WITH DEVICE NAME
if [ "${MOUNT_FOUND}" != "1" ]
then
MOUNT=$( mount | grep "/dev/${TARGET} " | awk 'END{print $3}' )
if [ "${MOUNT}" = "" ]
then
MOUNT="-"
else
local MOUNT_FOUND=1
fi
fi
# GET LABEL/MOUNT FOR UFS/zfs(8)/msdosfs(8) FILESYSTEM
case ${TYPE} in
(freebsd-ufs)
LABEL=$( tunefs -p /dev/${TARGET} 2>&1 | awk '/volume label/ {print $5}' )
if [ "${LABEL}" = "" ]
then
LABEL="-"
else
LABEL="ufs/${LABEL}"
local LABEL_FOUND=1
fi
(freebsd-zfs)
# zfs(8) IS NEVER MOUNTED BY RAW DEVICE NAME
# SO NO NEED TO CHECK IF MOUNT_FOUND = 1 HERE
MOUNT="<ZFS>"
local MOUNT_FOUND=1
(msdosfs)
LABEL=$( file -s /dev/${DEV} | tr ',' '\n' | awk -F '"' '/label:/ {print $2}' )
then
LABEL="-"
else
LABEL="msdosfs/${LABEL}"
local LABEL_FOUND=1
fi
(exfat)
if which exfatlabel 1> /dev/null 2> /dev/null
then
LABEL=$( exfatlabel /dev/${DEV} 2> /dev/null )
then
LABEL="-"
else
LABEL="exfat/${LABEL}"
local LABEL_FOUND=1
fi
fi
esac
# GET LABEL USING glabel(8)
if [ "${LABEL_FOUND}" != "1" ]
then
# TRY GLABEL MOUNTPOINT AS msdosfs MOUNT IS NOT POSSIBLE WITHOUT GPT/MBR
local GLABEL_GREP=$( echo "${GLABEL}" | grep -v ufsid | grep "${TARGET}\$" )
if [ "${GLABEL_GREP}" = "" ]
then
LABEL="-"
else
while read PROVIDER STATUS DEVICE
do
LABEL=$( echo "${GLABEL_GREP}" | grep -m 1 "${TARGET}" | awk '{print $1}' )
local LABEL_FOUND=1
break
done << ______EOF
$( echo "${GLABEL_GREP}" )
______EOF
fi
fi
# GET MOUNT USING glabel(8)
then
if [ "${GLABEL_GREP}" != "" ]
then
do
MOUNT=$( mount | grep "${PROVIDER}" | awk 'END{print $3}' )
then
MOUNT="-"
else
local MOUNT_FOUND=1
fi
break
done << ______EOF
______EOF
fi
fi
# GET MOUNT FROM fuse(8)
then
local FUSE_PIDS=$( pgrep mount.exfat ntfs-3g | tr '\n' ',' | sed '$s/.$//' )
if [ "${FUSE_PIDS}" != "" ]
then
local FUSE_MOUNTS=$( ps -p "${FUSE_PIDS}" -o command | sed 1d | sort -u )
MOUNT=$( echo "${FUSE_MOUNTS}" | grep "/dev/${TARGET} " | awk '{print $3}' )
then
MOUNT="-"
else
local MOUNT_FOUND=1
fi
fi
fi
# GET LABEL FROM gpart(8)
then
LABEL=$( gpart show -p -l ${DEV} 2> /dev/null | sed 's|=>||g' | sed 's-\[active\]--g' | grep "${TARGET} " | awk '{print $4}' )
if [ "${LABEL}" = "" -o "${LABEL}" = "(null)" ]
then
LABEL="-"
else
LABEL="gpt/${LABEL}"
fi
fi
SWAP_FOUND=0
# __mount_label() ENDED
# LIST BLOCK DEVICES
__list_block_devices() {
# FIRST 1000 DEVICES OF EACH CLASS SHOULD DO
for I in ada da mmcsd md
do
ls -1 /dev/${I}[0-9] 2> /dev/null
ls -1 /dev/${I}[0-9][0-9] 2> /dev/null
ls -1 /dev/${I}[0-9][0-9][0-9] 2> /dev/null
done \
| sed 's|/dev/||g' \
| sort -u \
| sed '/^s*$/d'
# __list_block_devices() ENDED
# PRINT DEVICES AND PARTITIONS
__print_parts() { # 1=NAME 2=TYPE 3=SIZE 4=SIZE_FREE
local NAME=${1}
local TYPE=${2}
local SIZE=${3}
local SIZE_FREE=${4}
case ${TYPE} in
(free)
# REMOVE BRACKETS FROM SIZE
local SIZE_FREE=$( echo ${SIZE_FREE} | tr -d '()' )
# FIRST 16 SECTORS ARE ALWAYS EMPTY ON bsdlabel(8) PARTITION SCHEMA
[ "${SIZE_FREE}" = "8.0K" ] && return
# OUTPUT
printf "${FORMAT}" "<FREE>" - - ${SIZE_FREE} "-" ${LABEL} ${MOUNT}
# NEEDED FOR bsdlabel(8) ON WHOLE DISK WITHOUT PARTITION
# WORKAROUND FOR gpart(8) BUG 241004
# https://bugs.freebsd.org/bugzilla/show_bug.cgi?id=241004
if [ "${TYPE}" = "!0" ]
then
local TYPE=freebsd-ufs
fi
local SIZE=$( echo ${SIZE} | tr -d '()' )
[ "${LABEL}" = "" ] && local LABEL="-"
[ "${MOUNT}" = "" ] && local MOUNT="-"
__major_minor ${NAME}
printf "${FORMAT}" ${NAME} ${MAJ} ${MIN} ${SIZE} ${TYPE} ${LABEL} ${MOUNT}
if [ -e /dev/${NAME}.eli ]
then
# GET GELI MOUNT/LABEL/MAJOR/MINOR
__major_minor ${NAME}.eli
__type ${NAME}.eli
__mount_label ${NAME}.eli
printf "${FORMAT}" ${NAME}.eli ${MAJ} ${MIN} ${SIZE} ${TYPE} ${LABEL} ${MOUNT}
MOUNT="-"
fi
esac
# __print_parts() ENDED
# WHEN GPART OUTPUT EXISTS (partition table / not entire device)
__gpart_present() { # 1=DEV
local DEV=${1}
local TYPE="-"
local SIZE="-"
local SIZE_FREE="-"
[ ! -e /dev/${DEV} ] && return
# WORKAROUND FOR gpart(1) BUG 240998
# https://bugs.freebsd.org/bugzilla/show_bug.cgi?id=240998
TYPE_EXFAT_HELPER_DEVICE=$( gpart show -p ${DEV} | head -1 | sed 's-\[active\]--g' | awk '{print $5}' 2> /dev/null )
if [ "${TYPE_EXFAT_HELPER_DEVICE}" = "MBR" ]
then
TYPE_EXFAT_HELPER=$( fstyp -u /dev/${DEV} 2> /dev/null )
if [ "${TYPE_EXFAT_HELPER}" = "exfat" ]
then
TYPE=exfat
SIZE=$( diskinfo -v ${DEV} 2> /dev/null| awk '/mediasize in bytes/ {print $NF}' | tr -d '()' )
__print_parts ${DEV} ${TYPE} ${SIZE} -
continue
fi
fi
# READ PARTITIONS OF PROVIDER
local GPART=$( gpart show -p ${DEV} 2> /dev/null | sed 's-\[active\]--g' | sed 's|=>||g' )
# PARSE gpart(8) OUTPUT
echo "${GPART}" \
| while read BEG END NAME TYPE SIZE SIZE_FREE
do
# VISITED ONLY ONCE FOR WHOLE DEVICE
if [ ${LEVEL_DEV} = "0" ]
then
# WHOLE DEVICE
LEVEL_DEV=1
FORMAT="${FORMAT_L0}"
__print_parts ${NAME} ${TYPE} ${SIZE} ${SIZE_FREE}
else
# PARTITION
FORMAT="${FORMAT_L1}"
local GPART_PARTS=$( gpart show -p ${NAME} 2> /dev/null | sed 's-\[active\]--g' | sed 's|=>||g' )
if [ "${GPART_PARTS}" != "" ]
then
# PARTITION IN PARTITION
[ ! -e /dev/${NAME} ] && return
# PARSE DEVICE
echo "${GPART_PARTS}" \
| while read BEG END NAMEONE TYPE SIZE SIZE_FREE
do
if [ ${LEVEL_PAR} = "0" ]
then
# WHOLE DEVICE
LEVEL_PAR=1
else
# PARTITION
FORMAT="${FORMAT_L2}"
fi
# CHECK IF SWAP IS ENABLED FOR SWAP DEVICES
[ "${TYPE}" = "freebsd-swap" ] && __swap_mount ${NAMEONE}
__mount_label ${NAMEONE}
__print_parts ${NAMEONE} ${TYPE} ${SIZE} ${SIZE_FREE}
done
else
# FILESYSTEM
[ "${TYPE}" = "freebsd-swap" ] && __swap_mount ${DEV}
fi
fi
done
# __gpart_present() ENDED
# WHEN GPART OUTPUT DO NOT EXISTS (no partition table / entire device)
__gpart_absent() { # 1=DEV
local DEV=${1}
# EXIT IF DEVICE DOES NOT EXISTS
local SIZE=$( diskinfo -v ${DEV} 2> /dev/null | awk '/mediasize in bytes/ {print $NF}' | tr -d '()' )
local SIZE_FREE="-"
__type ${DEV}
__mount_label ${DEV}
[ "${SIZE}" = "" ] && local SIZE="-"
[ "${TYPE}" = "" ] && local TYPE="-"
__print_parts ${DEV} ${TYPE} ${SIZE} ${SIZE_FREE}
# __gpart_absent() ENDED
# PARSE ARGUMENTS IF THERE ARE ANY
LEVEL_DEV=0
LEVEL_PAR=0
GLABEL=$( glabel status | sed 1d )
DISKS=$( __list_block_devices )
case ${#} in
(0)
# LIST ALL DISKS
(1)
# SINGLE ARGUMENT MEANS SINGLE DISK OR HELP
case ${1} in
(h|-h|--h|help|-help|--help)
__usage
esac
# SINGLE DISK CHECK
if echo "${DISKS}" | grep -q -- "${1}"
then
DISKS="${1}"
else
echo "NOPE: disk '${1}' does not exist in the system"
echo
__usage
fi
# ONLY '0' and '1' ARGUMENTS ARE COVERED
__usage
esac
# SET OUTPUT FORMAT AND PRINT HEADER
FORMAT_L0="%-14s %3s:%-3s %4s %-14s %20s %s\n"
FORMAT_L1=" %-12s %3s:%-3s %4s %-14s %20s %s\n"
FORMAT_L2=" %-10s %3s:%-3s %4s %-14s %20s %s\n"
printf "${FORMAT}" DEVICE MAJ MIN SIZE TYPE LABEL MOUNT
# DO THE JOB
echo "${DISKS}" \
| while read DEVICE
do
if gpart show ${DEVICE} 1> /dev/null 2> /dev/null
then
__gpart_present ${DEVICE}
else
__gpart_absent ${DEVICE}
fi
done
#!/bin/bash
#Use smartctl to get Serial Number - else dmesg is used
USESMART=2
#save glabel status to temporary file
CACHEGLABEL=0
if [ $CACHEGLABEL -eq 0 ]
then
GLCMD="glabel status"
else
GLTMP=/var/tmp/$0.glabel
glabel status > $GLTMP
GLCMD="cat $GLTMP"
fi
ADALOW=`ls /dev/ada[0-9] 2>/dev/null`
ADAHIGH=`ls /dev/ada[0-9][0-9] 2>/dev/null`
DALOW=`ls /dev/da[0-9] 2>/dev/null`
DAHIGH=`ls /dev/da[0-9][0-9] 2>/dev/null`
#check if all device nodes exist or skip
if [[ $ADALOW == *ls* ]]
then
$DALOW=
fi
if [[ $ADAHIGH == *ls* ]]
then
$ADAHIGH=
fi
if [[ $DALOW == *ls* ]]
then
$DALOW=
fi
if [[ $DAHIGH == *ls* ]]
then
$DAHIGH=
fi
for FILE in $ADALOW $ADAHIGH $DALOW $DAHIGH
do
DEV=${FILE##'/dev/'}
#echo -n "${DEV}: "
if [ $USESMART -eq 0 ]
then
SERIAL=`grep $DEV: /var/log/dmesg.today |grep -i Serial | awk '{print $(NF)}'`
elif [ $USESMART -eq 1 ]
then
SERIAL=`smartctl -a $FILE | grep -i 'Serial Number'| awk '{print $(NF)}'`
else
SERIAL=$(smartctl -a $FILE | grep -i 'serial number' | awk '{print $(NF)}')
fi
#this skips all ufs drives
#GPTID=`$GLCMD |grep 2$ |grep ${DEV}p|cut -d' ' -f1`
GPTID=$($GLCMD | awk -v pat="^${DEV}" '$3~pat{print $1, $3"\n"}')
if [ "${GPTID}x" == 'x' ]
then
GPTID="No GPTID"
fi
if [ "${SERIAL}x" == 'x' ]
then
$SERIAL="Not found"
fi
echo ${DEV}: Serial $SERIAL \; GPTID=$GPTID
done
if [ $CACHEGLABEL -eq 1 ]
then
rm $GLTMP
fi
