Not Sure what hard drive has failed?
BTW
I have had drives fail in the past. Replace the drive and replace via GUI. Simple enough.
This situation is a little different. I am confused if the drive has actually failed or FreeNas got stuck replacing a drive.
From the "view disk" page, it shows me all the drives and reports a drive size & serial (usually a failed drive does not).
From the "volume status" page, If I choose the "UNAVAIL" disk and click "replace", my system does not find a valid disk
Version:FreeNAS-9.10.2-U6 (561f0d7a1)
Setup (general): 10 x 3TB drives in 5 x mirrored vdevs (production), 2 x 1TB SSD in 1 x mirrored vdev (production), 5 x 3TB in 1 x raidz vdev (backups), 1 x 3TB spare, 1 x 400GB PCI (slog), 1 x 240GB L2
Devices:
[root@cdanas002] ~# camcontrol devlist
<ATA ST3000DM001-1CH1 CC29>		at scbus0 target 0 lun 0 (pass0,da0)
<ATA ST3000DM001-1CH1 CC29>		at scbus0 target 4 lun 0 (pass1,da1)
<ATA ST3000DM001-1CH1 CC29>		at scbus0 target 6 lun 0 (pass2,da2)
<ATA ST3000VN000-1HJ1 SC60>		at scbus0 target 9 lun 0 (pass3,da3)
<ATA ST3000DM008-2DM1 CC26>		at scbus0 target 12 lun 0 (pass4,da4)
<ATA ST3000DM008-2DM1 CC26>		at scbus0 target 13 lun 0 (pass5,da5)
<ATA ST3000DM008-2DM1 CC26>		at scbus0 target 14 lun 0 (pass6,da6)
<ATA ST3000DM008-2DM1 CC26>		at scbus0 target 15 lun 0 (pass7,da7)
<ATA SanDisk SDSSDXPS 00RL>		at scbus1 target 0 lun 0 (pass8,da8)
<ATA Crucial_CT1024MX MU03>		at scbus1 target 1 lun 0 (pass9,da9)
<ATA Crucial_CT1024MX MU03>		at scbus1 target 2 lun 0 (pass10,da10)
<ATA ST3000DM001-1CH1 CC29>		at scbus2 target 0 lun 0 (pass11,da11)
<ATA ST3000DM001-1CH1 CC29>		at scbus2 target 3 lun 0 (pass12,da12)
<ATA ST3000DM001-1CH1 CC29>		at scbus2 target 4 lun 0 (pass13,da13)
<ATA ST3000DM001-1CH1 CC29>		at scbus2 target 5 lun 0 (pass14,da14)
<ATA ST3000DM001-1CH1 CC29>		at scbus2 target 6 lun 0 (pass15,da15)
<ATA ST3000DM001-1CH1 CC29>		at scbus2 target 11 lun 0 (pass16,da16)
<ATA ST3000DM008-2DM1 CC26>		at scbus2 target 12 lun 0 (pass17,da17)
<ATA ST3000DM008-2DM1 CC26>		at scbus2 target 13 lun 0 (pass18,da18)
<Kingston DataTraveler 2.0 PMAP>   at scbus8 target 0 lun 0 (pass19,da19)
<Kingston DataTraveler 2.0 PMAP>   at scbus9 target 0 lun 0 (pass20,da20)
DeviceStatus:
[root@cdanas002] ~# glabel status
									  Name  Status  Components
gptid/632bbce1-30d7-11e6-a99f-00e081c5a93e	 N/A  nvd0p1
gptid/61e3aafa-30d7-11e6-a99f-00e081c5a93e	 N/A  da0p2
gptid/fb43cc18-30db-11e6-a99f-00e081c5a93e	 N/A  da1p2
gptid/42deccfc-30dc-11e6-a99f-00e081c5a93e	 N/A  da2p2
gptid/44fe493e-7049-11e6-af63-00e081c5a93e	 N/A  da3p2
gptid/1236b0ac-b4f7-11e6-a925-00e081c5a93e	 N/A  da4p2
gptid/34a8ef59-b502-11e6-a925-00e081c5a93e	 N/A  da5p2
gptid/8d2722d2-c9e8-11e6-a925-00e081c5a93e	 N/A  da6p2
gptid/6850ae5b-ffbb-11e6-973f-00e081c5a93e	 N/A  da7p2
gptid/62f706f1-30d7-11e6-a99f-00e081c5a93e	 N/A  da8p1
gptid/2a17f3e2-a443-11e6-a46a-00e081c5a93e	 N/A  da9p2
gptid/2a59dd00-a443-11e6-a46a-00e081c5a93e	 N/A  da10p2
gptid/9a51538d-30dc-11e6-a99f-00e081c5a93e	 N/A  da11p2
gptid/63c6a1c2-30d7-11e6-a99f-00e081c5a93e	 N/A  da12p2
gptid/6401a24e-a49d-11e6-a46a-00e081c5a93e	 N/A  da13p2
gptid/649d4853-a49d-11e6-a46a-00e081c5a93e	 N/A  da14p2
gptid/61ad9ca4-a49d-11e6-a46a-00e081c5a93e	 N/A  da15p2
gptid/6347599e-a49d-11e6-a46a-00e081c5a93e	 N/A  da16p2
gptid/b35746ff-e1ca-11e6-a925-00e081c5a93e	 N/A  da17p2
gptid/2a4e9d36-013d-11e7-973f-00e081c5a93e	 N/A  da18p2
gptid/36d5323f-22c4-11e6-a8e1-00e081c5a93e	 N/A  da19p1
gptid/36f29657-22c4-11e6-a8e1-00e081c5a93e	 N/A  da19p2
gptid/373b6d5b-22c4-11e6-a8e1-00e081c5a93e	 N/A  da20p1
gptid/3758e52b-22c4-11e6-a8e1-00e081c5a93e	 N/A  da20p2
VolumeStatus:
[root@cdanas002] ~# zpool status CDANAS002_VOL01
  pool: CDANAS002_VOL01
 state: DEGRADED
  scan: scrub repaired 0 in 7h7m with 0 errors on Fri Aug 18 19:07:13 2017
		NAME												STATE	 READ WRITE CKSUM
		CDANAS002_VOL01									 DEGRADED	 0	 0	 0
		  mirror-0										  ONLINE	   0	 0	 0
			gptid/61e3aafa-30d7-11e6-a99f-00e081c5a93e	  ONLINE	   0	 0	 0
			gptid/44fe493e-7049-11e6-af63-00e081c5a93e	  ONLINE	   0	 0	 0
		  mirror-2										  ONLINE	   0	 0	 0
			gptid/8d2722d2-c9e8-11e6-a925-00e081c5a93e	  ONLINE	   0	 0	 0
			gptid/63c6a1c2-30d7-11e6-a99f-00e081c5a93e	  ONLINE	   0	 0	 0
		  mirror-3										  ONLINE	   0	 0	 0
			gptid/fb43cc18-30db-11e6-a99f-00e081c5a93e	  ONLINE	   0	 0	 0
			gptid/1236b0ac-b4f7-11e6-a925-00e081c5a93e	  ONLINE	   0	 0	 0
		  mirror-4										  ONLINE	   0	 0	 0
			gptid/42deccfc-30dc-11e6-a99f-00e081c5a93e	  ONLINE	   0	 0	 0
			gptid/6850ae5b-ffbb-11e6-973f-00e081c5a93e	  ONLINE	   0	 0	 0
		  mirror-5										  DEGRADED	 0	 0	 0
			gptid/9a51538d-30dc-11e6-a99f-00e081c5a93e	  ONLINE	   0	 0	 0
			replacing-1									 DEGRADED	 0	 0	 0
			  spare-0									   DEGRADED	 0	 0	 0
				2758674182642180211						 UNAVAIL	  0	 0	 0  was /dev/gptid/eca80bf2-3334-11e6-83fa-00e081c5a93e
				gptid/34a8ef59-b502-11e6-a925-00e081c5a93e  ONLINE	   0	 0	 0
			  gptid/2a4e9d36-013d-11e7-973f-00e081c5a93e	ONLINE	   0	 0	 0
		logs
		  gptid/632bbce1-30d7-11e6-a99f-00e081c5a93e		ONLINE	   0	 0	 0
		cache
		  gptid/62f706f1-30d7-11e6-a99f-00e081c5a93e		ONLINE	   0	 0	 0
		spares
		  2578709866869120013							   INUSE	 was /dev/gptid/34a8ef59-b502-11e6-a925-00e081c5a93e
errors: No known data errors
[root@cdanas002] ~# glabel status | grep eca80bf2
[root@cdanas002] ~# glabel status | grep 2758674182642180211
[root@cdanas002] ~# glabel status | grep 34a8ef59
[root@cdanas002] ~# camcontrol identify da5 | grep serial
serial number		 C504F34C
Thanks
B
BTW
Forgot to mention:
FreeNas is not reporting a failed disk via the general status "Alert System".
BTW
If you are asking did I start a resilver operation lately, then the answer is no. The last failed drive I had was about 2 months ago.
If you are asking me did I just replace a drive now and start the resilver, that is the basis of my question. If I have a failed drive, not sure which one I have to replace.
Are there any other commands I can run to see if the drive has actually failed or not? Or if a resilver has happened (history)
Thanks
BTW
So I found this on the history of the volume.
[root@cdanas002] ~# zpool history CDANAS002_VOL01
History for 'CDANAS002_VOL01':
2016-06-12.15:54:03 zpool create -o cachefile=/data/zfs/zpool.cache -o failmode=continue -o autoexpand=on -O compression=lz4 -O aclmode=passthrough -O aclinherit=passthrough -f -m /CDANAS002_VOL01 -o altroot=/mnt CDANAS002_VOL01 mirror /dev/gptid/61e3aafa-30d7-11e6-a99f-00e081c5a93e /dev/gptid/62a04953-30d7-11e6-a99f-00e081c5a93e cache /dev/gptid/62f706f1-30d7-11e6-a99f-00e081c5a93e log /dev/gptid/632bbce1-30d7-11e6-a99f-00e081c5a93e spare /dev/gptid/63c6a1c2-30d7-11e6-a99f-00e081c5a93e
2016-06-12.15:54:03 zfs inherit mountpoint CDANAS002_VOL01
2016-06-12.15:54:03 zpool set cachefile=/data/zfs/zpool.cache CDANAS002_VOL01
2016-06-12.15:54:08 zfs set dedup=off CDANAS002_VOL01
2016-06-12.16:25:08 zpool add -f CDANAS002_VOL01 mirror /dev/gptid/bd02af39-30db-11e6-a99f-00e081c5a93e /dev/gptid/bdf99e42-30db-11e6-a99f-00e081c5a93e
2016-06-12.16:26:53 zpool add -f CDANAS002_VOL01 mirror /dev/gptid/fb43cc18-30db-11e6-a99f-00e081c5a93e /dev/gptid/fc315671-30db-11e6-a99f-00e081c5a93e
2016-06-12.16:28:53 zpool add -f CDANAS002_VOL01 mirror /dev/gptid/42deccfc-30dc-11e6-a99f-00e081c5a93e /dev/gptid/43d4e796-30dc-11e6-a99f-00e081c5a93e
2016-06-12.16:31:19 zpool add -f CDANAS002_VOL01 mirror /dev/gptid/9a51538d-30dc-11e6-a99f-00e081c5a93e /dev/gptid/9b0e4d4a-30dc-11e6-a99f-00e081c5a93e
2016-06-12.20:24:19 zfs create -o volblocksize=16K -V 2T CDANAS002_VOL01/PRODT2-CDANAS002-LUN-204
2016-06-12.21:13:12 zfs set sync=always CDANAS002_VOL01
2016-06-15.15:57:09 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 16723384952566375311
2016-06-15.15:57:09 zpool set cachefile=/data/zfs/zpool.cache CDANAS002_VOL01
2016-06-15.16:08:39 zpool replace -f CDANAS002_VOL01 9136240301091673146 gptid/eca80bf2-3334-11e6-83fa-00e081c5a93e
2016-06-15.16:08:54 zpool detach CDANAS002_VOL01 9136240301091673146
2016-06-16.08:31:42 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 16723384952566375311
2016-06-16.08:31:52 zpool set cachefile=/data/zfs/zpool.cache CDANAS002_VOL01
2016-08-02.18:26:06 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 16723384952566375311
2016-08-02.18:26:06 zpool set cachefile=/data/zfs/zpool.cache CDANAS002_VOL01
2016-08-02.18:43:45 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 16723384952566375311
2016-08-02.18:43:45 zpool set cachefile=/data/zfs/zpool.cache CDANAS002_VOL01
2016-08-02.19:05:26 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 16723384952566375311
2016-08-02.19:05:26 zpool set cachefile=/data/zfs/zpool.cache CDANAS002_VOL01
2016-08-15.16:29:42 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 16723384952566375311
2016-08-15.16:29:42 zpool set cachefile=/data/zfs/zpool.cache CDANAS002_VOL01
2016-08-15.17:50:41 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 16723384952566375311
2016-08-15.17:50:41 zpool set cachefile=/data/zfs/zpool.cache CDANAS002_VOL01
2016-08-15.20:31:20 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 16723384952566375311
2016-08-15.20:31:20 zpool set cachefile=/data/zfs/zpool.cache CDANAS002_VOL01
2016-08-15.20:50:23 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 16723384952566375311
2016-08-15.20:50:38 zpool set cachefile=/data/zfs/zpool.cache CDANAS002_VOL01
2016-08-19.13:46:38 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 16723384952566375311
2016-08-19.13:46:38 zpool set cachefile=/data/zfs/zpool.cache CDANAS002_VOL01
2016-08-21.00:00:09 zpool scrub CDANAS002_VOL01
2016-08-22.02:00:09 zpool scrub CDANAS002_VOL01
2016-08-23.04:00:09 zpool scrub CDANAS002_VOL01
2016-08-24.06:00:10 zpool scrub CDANAS002_VOL01
2016-08-25.08:00:09 zpool scrub CDANAS002_VOL01
2016-08-26.10:00:09 zpool scrub CDANAS002_VOL01
2016-08-27.12:00:10 zpool scrub CDANAS002_VOL01
2016-08-28.14:00:09 zpool scrub CDANAS002_VOL01
2016-08-29.16:00:09 zpool scrub CDANAS002_VOL01
2016-08-30.18:00:09 zpool scrub CDANAS002_VOL01
2016-09-01.02:10:56 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 16723384952566375311
2016-09-01.02:10:56 zpool set cachefile=/data/zfs/zpool.cache CDANAS002_VOL01
2016-09-01.09:27:53 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 16723384952566375311
2016-09-01.09:27:53 zpool set cachefile=/data/zfs/zpool.cache CDANAS002_VOL01
2016-09-01.09:37:58 zpool replace -f CDANAS002_VOL01 17967836871681542934 gptid/44fe493e-7049-11e6-af63-00e081c5a93e
2016-09-01.09:38:12 zpool detach CDANAS002_VOL01 17967836871681542934
2016-11-06.11:28:32 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 16723384952566375311
2016-11-06.11:28:42 zpool set cachefile=/data/zfs/zpool.cache CDANAS002_VOL01
2016-11-06.11:57:00 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 16723384952566375311
2016-11-06.11:57:05 zpool set cachefile=/data/zfs/zpool.cache CDANAS002_VOL01
2016-11-06.12:00:09 zpool scrub CDANAS002_VOL01
2016-11-13.12:36:33 zpool scrub CDANAS002_VOL01
2016-11-14.20:18:04 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 16723384952566375311
2016-11-14.20:18:04 zpool set cachefile=/data/zfs/zpool.cache CDANAS002_VOL01
2016-11-27.17:32:54 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 16723384952566375311
2016-11-27.17:32:54 zpool set cachefile=/data/zfs/zpool.cache CDANAS002_VOL01
2016-11-27.18:01:21 zpool scrub CDANAS002_VOL01
2016-11-27.18:13:26 zpool replace CDANAS002_VOL01 4561408088713390006 gptid/1236b0ac-b4f7-11e6-a925-00e081c5a93e
2016-11-27.18:13:45 zpool detach CDANAS002_VOL01 4561408088713390006
2016-11-27.19:08:39 zpool detach CDANAS002_VOL01 9150220252052241131
2016-11-27.19:33:02 zpool add -f CDANAS002_VOL01 spare /dev/gptid/34a8ef59-b502-11e6-a925-00e081c5a93e
2016-12-04.18:30:09 zpool scrub CDANAS002_VOL01
2016-12-12.00:00:09 zpool scrub CDANAS002_VOL01
2016-12-19.00:30:09 zpool scrub CDANAS002_VOL01
2016-12-24.09:52:21 zpool replace CDANAS002_VOL01 13759733357039705620 gptid/8d2722d2-c9e8-11e6-a925-00e081c5a93e
2016-12-24.09:52:37 zpool detach CDANAS002_VOL01 13759733357039705620
2016-12-26.06:00:09 zpool scrub CDANAS002_VOL01
2016-12-28.19:24:58 zfs create -s -o volblocksize=16K -V 4.5T CDANAS002_VOL01/prodt2-cdanas002-lun-205
2016-12-31.08:56:05 zfs create -s -o volblocksize=16K -V 300G CDANAS002_VOL01/templates-cdanas002-lun-206
2017-01-02.06:30:09 zpool scrub CDANAS002_VOL01
2017-01-09.12:00:10 zpool scrub CDANAS002_VOL01
2017-01-16.12:30:09 zpool scrub CDANAS002_VOL01
2017-01-23.18:00:09 zpool scrub CDANAS002_VOL01
2017-01-30.18:30:09 zpool scrub CDANAS002_VOL01
2017-02-04.15:44:35 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 16723384952566375311
2017-02-04.15:44:40 zpool set cachefile=/data/zfs/zpool.cache CDANAS002_VOL01
2017-02-04.17:06:43 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 16723384952566375311
2017-02-04.17:06:43 zpool set cachefile=/data/zfs/zpool.cache CDANAS002_VOL01
2017-02-07.00:00:09 zpool scrub CDANAS002_VOL01
2017-02-14.00:30:08 zpool scrub CDANAS002_VOL01
2017-02-21.06:00:09 zpool scrub CDANAS002_VOL01
2017-02-25.07:18:22 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 16723384952566375311
2017-02-25.07:18:22 zpool set cachefile=/data/zfs/zpool.cache CDANAS002_VOL01
2017-02-28.06:30:08 zpool scrub CDANAS002_VOL01
2017-03-02.21:45:29 zpool replace CDANAS002_VOL01 gptid/43d4e796-30dc-11e6-a99f-00e081c5a93e gptid/6850ae5b-ffbb-11e6-973f-00e081c5a93e
2017-03-04.19:46:40 zpool replace CDANAS002_VOL01 gptid/eca80bf2-3334-11e6-83fa-00e081c5a93e gptid/2a4e9d36-013d-11e7-973f-00e081c5a93e
2017-03-07.12:00:09 zpool scrub CDANAS002_VOL01
2017-03-14.18:00:09 zpool scrub CDANAS002_VOL01
2017-03-18.11:48:00 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 16723384952566375311
2017-03-18.11:48:11 zpool set cachefile=/data/zfs/zpool.cache CDANAS002_VOL01
2017-03-18.11:55:41 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 16723384952566375311
2017-03-18.11:55:41 zpool set cachefile=/data/zfs/zpool.cache CDANAS002_VOL01
2017-03-18.14:31:38 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 16723384952566375311
2017-03-18.14:31:38 zpool set cachefile=/data/zfs/zpool.cache CDANAS002_VOL01
2017-03-21.18:30:09 zpool scrub CDANAS002_VOL01
2017-03-29.00:00:09 zpool scrub CDANAS002_VOL01
2017-04-05.00:30:09 zpool scrub CDANAS002_VOL01
2017-04-12.06:00:09 zpool scrub CDANAS002_VOL01
2017-04-19.06:30:09 zpool scrub CDANAS002_VOL01
2017-04-26.12:00:09 zpool scrub CDANAS002_VOL01
2017-05-03.12:30:09 zpool scrub CDANAS002_VOL01
2017-05-05.15:04:54 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 16723384952566375311
2017-05-05.15:04:54 zpool set cachefile=/data/zfs/zpool.cache CDANAS002_VOL01
2017-05-10.18:00:09 zpool scrub CDANAS002_VOL01
2017-05-17.18:30:10 zpool scrub CDANAS002_VOL01
2017-05-25.00:00:10 zpool scrub CDANAS002_VOL01
2017-06-01.00:30:09 zpool scrub CDANAS002_VOL01
2017-06-08.06:00:10 zpool scrub CDANAS002_VOL01
2017-06-15.06:30:10 zpool scrub CDANAS002_VOL01
2017-06-17.11:16:56 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 16723384952566375311
2017-06-17.11:17:11 zpool set cachefile=/data/zfs/zpool.cache CDANAS002_VOL01
2017-06-17.11:23:07 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 16723384952566375311
2017-06-17.11:23:07 zpool set cachefile=/data/zfs/zpool.cache CDANAS002_VOL01
2017-06-17.13:42:23 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 16723384952566375311
2017-06-17.13:42:28 zpool set cachefile=/data/zfs/zpool.cache CDANAS002_VOL01
2017-06-22.12:00:09 zpool scrub CDANAS002_VOL01
2017-06-29.12:30:10 zpool scrub CDANAS002_VOL01
2017-07-06.18:00:11 zpool scrub CDANAS002_VOL01
2017-07-13.18:30:11 zpool scrub CDANAS002_VOL01
2017-07-21.00:00:11 zpool scrub CDANAS002_VOL01
2017-07-28.00:30:11 zpool scrub CDANAS002_VOL01
2017-07-31.17:01:12 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 16723384952566375311
2017-07-31.17:01:12 zpool set cachefile=/data/zfs/zpool.cache CDANAS002_VOL01
2017-07-31.18:27:02 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 16723384952566375311
2017-07-31.18:27:12 zpool set cachefile=/data/zfs/zpool.cache CDANAS002_VOL01
2017-07-31.18:33:05 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 16723384952566375311
2017-07-31.18:33:10 zpool set cachefile=/data/zfs/zpool.cache CDANAS002_VOL01
2017-08-04.06:00:11 zpool scrub CDANAS002_VOL01
2017-08-11.06:30:12 zpool scrub CDANAS002_VOL01
2017-08-18.12:00:12 zpool scrub CDANAS002_VOL01
2017-08-19.11:22:46 zfs create -s -o volblocksize=16K -V 3T CDANAS002_VOL01/PRODT2-CDANAS002-LUN-207
2017-08-19.11:22:51 zfs set org.freenas:description=Media Store CDANAS002_VOL01/PRODT2-CDANAS002-LUN-207
If you look at:
You notice there were 2 replace commands but no detach command.
Does that mean the resilver failed?
BTW
Can anyone assist on this with a definitive answer?
Did the drive actually fail or did the resilver process fail?
I cannot find any commands at this point that would say for sure.
Thanks
B
BTW
I was not able to get any help with clarification on this error. Even the bug tracker was no real help (https://bugs.freenas.org/issues/25704).
So here was the fix (make sure you have good backups):
  1. Get into the command line of Freenas
  2. Check the pool status of the DEGRADED pool
  3. Code:
    zpool status %NameOfYourPool%
  4. There will be a drive shown with a status as "UNAVAIL" (see first post for example)
  5. Manually remove the drive from the pool. (http://docs.oracle.com/cd/E19253-01/819-5461/6n7ht6qvt/index.html - example 4-10)
  6. Code:
    zpool detach %NameOfDrive% %NameOfPool%
  7. Check pool status again. It should show as healthy
  8. Now (in my case) FreeNas kicked/removed the spare drive associated with this volume, permanately
  9. Add the spare back into the pool (as per normal FreeNas procedures)
  10. Reboot system (not necessary but good idea)
