Hi all,
Came home from work to find my FN Corral install wasn't working. After a little investigation I found that my ZFS pool was DEGRADED. I might add I was running boot USBs in Mirror and the system was providing the following errors:
Despite the mirror regardless of which USB was in the system would not boot - thanks Corral! :(
I built Corral from scratch so didn't have many issues with it and found it ok! I had planned to migrate once FN 11.1 was released to enable the Docker migration, but this forced my hand.
I have 2 ZFS pools:
- WD_Green
- WD_Black
I grabbed a spare USB drive and installed clean FN 11. This immediatly found and picked up the WD_Green zfs pool and imported it. Great.
The WD_Black however - was encrypted and therefore didn't come up on the selection page.
So - I fired up a VirtualBox FreeBSD and with USB passthrough attempted to view the ZFS pool status and import the pool to the VM to grab the encryption key, but I get the same errors as above with the pool being unable to be imported.
Is the data lost?
Can I recover the disks and import the data?
In addition to this - the dockers I had were on the WD_Green drive so I have access to the .img what would be the best way to extract the data to use in jails I will now need to recreate?
Thanks
I have 2 ZFS pools:
- WD_Green
- WD_Black
Is the data lost?
Thanks
