Hello!
This is going to be my first post on the FreeNAS forums. I have experimented with FreeNAS before on a VM but never used it in real life.
Currently I am running Xpenology(DIY Synology) on my part scraped pretty random NAS but I can't really upgrade since the AMD support is lacking and the software is not really working for me anymore.
I am wondering if this hardware would support running FreeNAS. I really don't want to go experimenting with my NAS on live hardware if I am not a good percentage sure it will run stable. Have done that in the past too much.
Hardware:
Mobo: Gigabyte GA-F2A85XM-D3H
CPU: AMD A4-4000
Memory: Kingston HyperX Fury black HX318C10FBK2/8 (8GB)
Memory: Kingston HyperX KHX1866C11D3P1K2/8G (8GB)
Storage: 3x Seagate 3TB 7200RPM(Can't find the exact model number atm, are running fine for 3 years now)
Case: Fractal Design Define Mini
Power: Be Quiet! Pure Power L7 300W
I also have another I believe it is 600GB laptop HDD in there but that is used for little experiments and I am not planning to use that drive as a NAS drive. Maybe for experiments and non-critical data but let's leave that one out of the picture for now.
Main uses:
My questions:
Thank you so much for looking into this!
Hardware:
CPU: AMD A4-4000
Main uses:
- File sync server
- Backing up a Desktop and Two laptops
- Syncing to a Cloud Backup solution(Needs to be determined wich one)
- Stream a few movies(not much)
My questions:
- Can I run FreeNAS in a stable config on this hardware?
- Do I have enough resources to run a few(not too heavy) Docker containers(mainly webservers, small)
- I have a few bucks to make some small! upgrades to the system(if really needed or very well recommended) if needed, what?
