Wont boot after install of FreeNAS-11.2-BETA2 ("entropy device external interface")
cass101
I have done a fresh install of FreeNAS-11.2-BETA2 on a Hyper-V VM. (Windows server 20012 R2)
This issue occurred after the initial install of Beta 11.2 so I decided to re-install to eliminate any anomaly causing the issue.
After the second fresh install and setup was successful I decided to reboot the system and below and behold the boot gets stuck on "entropy device external interface"
The only kind of log I have is in the picture attached.
Please help.
Thanks in advance,
Cass
Arwen
It's almost certainly not the random number generator.
Many hangs are due to the NEXT thing to be initialized. That has not printed a message, (yet?).
I am not as familiar with FreeBSD / NAS boot up, so I can't help other than the above comments.
cass101
Thanks for the reply buddy. I guess for now I'll try and do a re-install and capture a log file to see what's going on. And then downgrade to the stable version which, hopefully, will fix the problem
FWIW, here is the next thing in sequence off my 11.1-U6 box.
Edit: Sorry, clipped the wrong stuff the first time.
FreeBSD clang version 5.0.0 (tags/RELEASE_500/final 312559) (based on LLVM 5.0.0
svn)
CPU: Intel(R) Xeon(R) CPU E5-2660 v2 @ 2.20GHz (2200.04-MHz K8-class CPU)
  Origin="GenuineIntel"  Id=0x306e4  Family=0x6  Model=0x3e  Stepping=4
  Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,C
MOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
  Features2=0x7fbee3ff<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,SMX,EST,TM2,SSSE3,CX
16,xTPR,PDCM,PCID,DCA,SSE4.1,SSE4.2,x2APIC,POPCNT,TSCDLT,AESNI,XSAVE,OSXSAVE,AVX
,F16C,RDRAND>
  AMD Features=0x2c100800<SYSCALL,NX,Page1GB,RDTSCP,LM>
  AMD Features2=0x1<LAHF>
  Structured Extended Features=0x281<FSGSBASE,SMEP,ERMS>
  XSAVE Features=0x1<XSAVEOPT>
  VT-x: PAT,HLT,MTF,PAUSE,EPT,UG,VPID,VID,PostIntr
  TSC: P-state invariant, performance statistics
real memory  = 139586437120 (133120 MB)
avail memory = 133476843520 (127293 MB)
Event timer "LAPIC" quality 600
ACPI APIC Table: <Cisco0 CiscoUCS>
FreeBSD/SMP: Multiprocessor System Detected: 40 CPUs
FreeBSD/SMP: 2 package(s) x 10 core(s) x 2 hardware threads
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ioapic0 <Version 2.0> irqs 0-23 on motherboard
ioapic1 <Version 2.0> irqs 24-47 on motherboard
ioapic2 <Version 2.0> irqs 48-71 on motherboard
SMP: AP CPU #29 Launched!
SMP: AP CPU #15 Launched!
SMP: AP CPU #26 Launched!
SMP: AP CPU #38 Launched!
SMP: AP CPU #39 Launched!
SMP: AP CPU #5 Launched!
SMP: AP CPU #13 Launched!
SMP: AP CPU #28 Launched!
SMP: AP CPU #30 Launched!
SMP: AP CPU #4 Launched!
SMP: AP CPU #23 Launched!
SMP: AP CPU #22 Launched!
SMP: AP CPU #8 Launched!
SMP: AP CPU #18 Launched!
SMP: AP CPU #1 Launched!
SMP: AP CPU #2 Launched!
SMP: AP CPU #34 Launched!
SMP: AP CPU #35 Launched!
SMP: AP CPU #36 Launched!
SMP: AP CPU #9 Launched!
SMP: AP CPU #7 Launched!
SMP: AP CPU #37 Launched!
SMP: AP CPU #6 Launched!
SMP: AP CPU #20 Launched!
SMP: AP CPU #11 Launched!
SMP: AP CPU #14 Launched!
SMP: AP CPU #3 Launched!
SMP: AP CPU #16 Launched!
SMP: AP CPU #27 Launched!
SMP: AP CPU #19 Launched!
SMP: AP CPU #31 Launched!
SMP: AP CPU #24 Launched!
SMP: AP CPU #25 Launched!
SMP: AP CPU #10 Launched!
SMP: AP CPU #33 Launched!
SMP: AP CPU #32 Launched!
SMP: AP CPU #12 Launched!
SMP: AP CPU #21 Launched!
SMP: AP CPU #17 Launched!
Timecounter "TSC-low" frequency 1100022122 Hz quality 1000
random: entropy device external interface
kbd1 at kbdmux0
random: registering fast source Intel Secure Key RNG
random: fast provider: "Intel Secure Key RNG"
nexus0
cryptosoft0: <software crypto> on motherboard
aesni0: <AES-CBC,AES-XTS,AES-GCM,AES-ICM> on motherboard
padlock0: No ACE support.
acpi0: <Cisco0 CiscoUCS> on motherboard
acpi0: Power Button (fixed)
cpu0: <ACPI CPU> numa-domain 0 on acpi0
cpu1: <ACPI CPU> numa-domain 0 on acpi0
cpu2: <ACPI CPU> numa-domain 0 on acpi0
cpu3: <ACPI CPU> numa-domain 0 on acpi0
cpu4: <ACPI CPU> numa-domain 0 on acpi0
cpu5: <ACPI CPU> numa-domain 0 on acpi0
cpu6: <ACPI CPU> numa-domain 0 on acpi0
cpu7: <ACPI CPU> numa-domain 0 on acpi0
cpu8: <ACPI CPU> numa-domain 0 on acpi0
cpu9: <ACPI CPU> numa-domain 0 on acpi0
cpu10: <ACPI CPU> numa-domain 0 on acpi0
cpu11: <ACPI CPU> numa-domain 0 on acpi0
cpu12: <ACPI CPU> numa-domain 0 on acpi0
cpu13: <ACPI CPU> numa-domain 0 on acpi0
cpu14: <ACPI CPU> numa-domain 0 on acpi0
cpu15: <ACPI CPU> numa-domain 0 on acpi0
cpu16: <ACPI CPU> numa-domain 0 on acpi0
cpu17: <ACPI CPU> numa-domain 0 on acpi0
cpu18: <ACPI CPU> numa-domain 0 on acpi0
cpu19: <ACPI CPU> numa-domain 0 on acpi0
cpu20: <ACPI CPU> numa-domain 1 on acpi0
cpu21: <ACPI CPU> numa-domain 1 on acpi0
cpu22: <ACPI CPU> numa-domain 1 on acpi0
cpu23: <ACPI CPU> numa-domain 1 on acpi0
cpu24: <ACPI CPU> numa-domain 1 on acpi0
cpu25: <ACPI CPU> numa-domain 1 on acpi0
cpu26: <ACPI CPU> numa-domain 1 on acpi0
cpu27: <ACPI CPU> numa-domain 1 on acpi0
cpu28: <ACPI CPU> numa-domain 1 on acpi0
cpu29: <ACPI CPU> numa-domain 1 on acpi0
cpu30: <ACPI CPU> numa-domain 1 on acpi0
cpu31: <ACPI CPU> numa-domain 1 on acpi0
cpu32: <ACPI CPU> numa-domain 1 on acpi0
cpu33: <ACPI CPU> numa-domain 1 on acpi0
cpu34: <ACPI CPU> numa-domain 1 on acpi0
cpu35: <ACPI CPU> numa-domain 1 on acpi0
cpu36: <ACPI CPU> numa-domain 1 on acpi0
cpu37: <ACPI CPU> numa-domain 1 on acpi0
cpu38: <ACPI CPU> numa-domain 1 on acpi0
cpu39: <ACPI CPU> numa-domain 1 on acpi0
attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
atrtc0: registered as a time-of-day clock, resolution 1.000000s
Event timer "RTC" frequency 32768 Hz quality 0
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 950
Event timer "HPET" frequency 14318180 Hz quality 350
Event timer "HPET1" frequency 14318180 Hz quality 340
Event timer "HPET2" frequency 14318180 Hz quality 340
Event timer "HPET3" frequency 14318180 Hz quality 340
Event timer "HPET4" frequency 14318180 Hz quality 340
Event timer "HPET5" frequency 14318180 Hz quality 340
Event timer "HPET6" frequency 14318180 Hz quality 340
Event timer "HPET7" frequency 14318180 Hz quality 340
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff numa-domain 0 on acpi0
pcib0: _OSC returned error 0x10
pci0: <ACPI PCI bus> numa-domain 0 on pcib0
pcib1: <ACPI PCI-PCI bridge> irq 26 at device 1.0 numa-domain 0 on pci0
pci1: <ACPI PCI bus> numa-domain 0 on pcib1
cass101
So after forgetting about the Freenas VM, the server has been off, I opened up Hyper-V manager today to see that it's now working. Very bizarre.
Then rebooted and faced with the same issue. I think it may be a virtual hdd problem?
Arwen
Based on @Elliot Dierksen's boot time messages, I'd say that it's the keyboard, (or virtual keyboard), "kbd1 at kbdmux0".
Don't know how to fix it in your case, sorry.
Had similar problem long, long ago with a dumb terminal and Solaris SPARC server. The dumb terminal died and whence Solaris got to the point of installing the serial console drivers, the OS hung. Turns out the dumb terminals handshake lines were hanging any further output. Dis-connect the broken thing and all was good, (and get another recycled terminal...).
Yes, I had some unpredictable results along those same lines. It did seem to vary depending on whether I was attached via the baseboard management card, or a physical keyboard/mouse on a KVM. I never fully pinned it down, but it did seem that the virtual USB drive that the baseboard management card would attach did seem to annoy things during the boot process. Sorry, I know that isn't terribly helpful. If I hadn't mentioned before, both my FreeNAS units are bare metal.
cass101
Downgraded to the stable freenas version and all seems to be fine now (11.1-U6)
