Will this work with LSI 9211-8i 6G SAS HBA?
Cobra68
Hi. New here with a question. Will the LSI 9211-8i 6G SAS HBA FW:P20 IT Mode support (4) 14TB WD drives in a Dell Poweredge T330? I am considering setting up a RaidZ2 with the 4 14TB drives with a usable pool of 25.46TB. The T330 has 8 drive bays, backplane, and I will use the LSI 9211-8i to use all 8 drives. I am planning on an additional 4 4TB drives to fill up the server as a second pool.
The T330 currently has 8GB of ECC RAM but know I need to upgrade to more, maybe 16GB or 32GB. The CPU is a Intel Xeon CPU E3-1220 v5 @ 3.00GHz.
Thanks!
Scharbag
I have a single 9211-8i with newly 40 drives connected to it right now. So your should work just fine unless there is some strange size limit I am not aware of. I run 6TB, 4TB and 3 TB drives currently. As long as the backplane is SAS2, then it should be fine though.
Perhaps someone else could confirm?
