duncandoo
- Mar 5, 2022
cat /sys/class/scsi_host/host0/link_power_management_policy
shows that med_power_with_dipm
is the default setting in TrueNAS SCALE. I'm guessing this is inherited from Debian. This setting is for a feature called link power management, which seems to be closely related to agressive link power management, and controls the power sent to the SCSI host controllers. It is distinct from the advanced power management, that controls how the disks attached to the SCSI controller behave. This page, for Archlinux, suggests the purpose of this setting is to save power when the disks are idle, about 1-1.5W, and this manpage, from Debian, suggests it is a useful setting to change according to whether a laptop is plugged into mains power or not. There are also hints that this setting might cause some HDDs trouble, and this is indeed the problem I've been having and seems also to be experienced by @polakkenak here and is described here.I have been having this problem of zpool write errors appearing since I built the system; I've never got out of testing. ASRock have been great, and replaced the motherboard as the inital indications pointed to a faulty SATA connector. The replacement had the same problem. I couldn't replicate the problem in either Proxmox or Windows on the same hardware. They sent me a specific BIOS to try, which didn't help. Then I accidentally stumbled into @polakkenak 's post which pointed me to this setting. I have changed mine to
medium_power
and have no more instances of write errors.So, going back to the question. Why is this the default setting in TrueNAS SCALE? Saving 1-1.5W when HDDs are idle seems like a trivial saving, especially when the recommended settings for HDDs seem to be that APM is turned off. TrueNAS SCALE is not designed to run on a laptop, so running on battery power is irrelevant, and there is potential to cause problems. What is the advantage of this setting? Is this a deliberate choice of TrueNAS or just inherited from generic Debian where it may be a sensible default setting?
And finally, does this setting really solve the problem, or am I just covering up some deeper badness? And what is the best way to get this setting to 'stick' on reboot if there are those that need to change it: there isn't any GUI setting for it? Is the solution suggested in the minisforum discussion the best/only way?
