MalVeauX
- Aug 6, 2020
Hi all,
I'm curious what everyone's experience so far is with various options of HDD's with current release FreeNAS (11.3) and ZFS in general.
I'm genuinely curious about the following:
Enterprise class:
Ultrastar/Gold (WD, HGST, Hitachi) vs EXOS (SG) vs MG (Toshiba)
I was seeing a different in how SG outputs SMART information. Does this really matter?
Is it truly worth using enterprise level drives in a system with mirrors (no parity based redundancy)?
Reliability and lower chance of any failure of any kind would be the primary attributes wanted (not speed); if that's the case, are Enterprise class drives the way to go? Or would a NAS oriented drive be basically as good? Not expecting 10 year life span. Goal is closer to 3~4 years of spin time (36k hours).
If you had one fail, and replaced it, would you cringe to mix an Ultrastar and EXOS drive of same capacity together in a pool as replacement?
Consumer class:
All the typical desktop targeted drives, NAS drives, etc. But avoiding SMR drives (WD RED for example) like the plague. If you were going to gamble on these class drives (WD blues, greens, blacks, reds; white labels; Seagate baracuda, ironwolf), which ones would you ideally gamble on? Obviously the NAS oriented drives (if CMR) are probably more ideal, but are people really gambling on these white lable shucks or standard non-NAS oriented consumer desktop drives (assuming a redundancy scheme is used)?
Renew/Refurb:
Do any of you gamble on refurbished enterprise drives? These seem all over and people use them, but this just seems really risky. Other than getting one, doing in depth testing, sector testing, etc, which takes days probably and then trusting them with data? Any commentary from a parity based redundancy scheme or mirror scheme point of view when using such drives?
Very best,
Enterprise class:
Consumer class:
Renew/Refurb:
Very best,
