audiophile20
- Sep 21, 2016
Firstly, Thank You! for all the information on this site for the newbies like me. I have tried to learn from the stickies and the forum. Still reading but feel I am ready to order the HW. I understand the specs maybe a bit excessive, but it is mostly current tech, and in this case excess is fun :)
My questions on the build are listed below. Also, the list of HW is also listed for your review/consideration. Thanks in advance for your comments/input!!!
Questions:
1. CPU - Any reason I should rather choose the E5-1650v3? I am trying to trade off performance vs. TDP. I am not sure FreeNAS needs a 6 core CPU. Does it really matter? NOTE: Choice of memory will make a difference on the processor. Please see point-3.
2. Controller/HBA - I understand that you can buy used, but this is a 12Gb/s card and makes for a simple build; maybe overkill but simplifies build.
3. Memory - will 64GB be enough or do I need to move to a larger size? If I need more memory then I will have to move to the LGA-2011 socket. How will the performance be with 64GB as max size?
4. NICs - Use onboard NICs. Will upgrade to 10Gb network eventually. Any problems with the NICs I should plan to workaround?
5. RAID - Any RAID constraints I should be thinking about or do I have the freedom pick from the list? NOTE: Planning for RAID-6 type parity array. Also, should I build multiple arrays rather than one large one? Based on your knowledge/experience please comment on structuring arrays - size, type, etc.
Hardware:
- Norco 4224 (case purchased)
- Intel Xeon E3-1275 v5 SkyLake 3.6 GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1151 80W
- ECC 64GB (Max for motherboard. Samsung per Supermicro)
- Supermicro X11SAT-F Workstation - Intel C236 Chipset - Socket H4 LGA-1151
- LSI 9305-24i x8 lane, PCIe 3.0 Full Height SAS SAS 9305 12 Gb/s SAS HBA
- Using motherboard NICs
- HGST HDD (NAS Class) 4TB (24x)
- SanDisk 16GB Ultra Fit CZ43 USB 3.0 Flash Drive, (SDCZ43-016G-G46) for FreeNAS
- Other: Noctua cooler, a PSU 750W (recycling) and Norco SFF8087 to SFF-8087 (6x) cables.
Purpose:
- Serve as a FreeNAS box to store and serve media
- Primary storage/back-up for PCs on the network. I have a lot of data and need a central repository.
- All Win10 PCs on the network
- Expecting to load with Hitachi 4TB NAS drives (24 of them. Will start with 12 and nuild out from there)
Objectives:
- Fast, Reliable, 24/7 system - NIC is expected bottle neck at 1 Gb network
- Remote management capabilities
- FreeNAS maintenance activities - faster better
- Enough HW headroom (for added complexity)
- Planned size 24 x 4TB = 96TB (start with 12 disks and build to 24)
- RAID configuration - undecided; will need redundancy
Questions:
Hardware:
Purpose:
Objectives:
