Where are my files in my Snapshots?
Fuganater
Hey there,
So my wife recently deleted some files and I was like "no worries, I have snapshots!". I have previous versions configured so I can recover things via Windows. Only problem is that the previous versions are empty. My guess is I screwed something up.
Here are my Previous Versions:
Share folder is empty...
It should have data in it right?
It is configured:
And there are snapshots:
So what am I missing?
Fuganater
It is my pool.
Mlovelace
Since it's your pool you will have to clone the snapshot with the data and make a new share for it to get the file you need. For the shadowcopy in Windows to work the snapshot has to be the dataset that is being shared, not the whole pool.
Fuganater
Vol1 is my share
Fuganater
Figured it out. I didn't check the 'reclusive' checkbox so my snap was only of that folder, nothing in the other datasets. Doh!
