mav3rek
- Feb 12, 2015
I have setup a snapshot task and it appears to be running correctly. I have one volume setup and all my datasets are within that volume. The volume is /mnt/vol1, and I have the snapshot task set to /vol1, daily from 9am to 6 pm every 4 hours and to keep 2 weeks. This had worked previously, and when I went to the Windows share and right clicked and went into previous versions it did show the different snapshots and I had the ability to search prior days of snapshots.
I ran into some issue with jails/datasets/plugins and blew everything up and started from scratch. Fresh install, etc. Now I have everything back working, except the snapshots/previous versions. The snapshots appear to work, I can go into the snapshots tab on the storage section and see the 3 different snapshots it took yesterdsay, but that previous versions tab is blank.
Any help would be greatly appreciated!!
Thanks,
Mav
Thanks,
Mav
