What HBA would you use?
richcj10
Hi, Haven't used Freenas in a long time. I feel it has gotten much stronger and more features. As such I want to migrate over.
Right now I have a Rackable Systems 16 Bay SE3016.
To control that I am currently using a LSI 8888ELP.
I do remember flashing LSI cards to IT mode in DOS but it was a while ago and I don't think after doing research it is even possible. So my question is, what HBA would work with the SE3016 in JBOD configuration?
thanks,
Rick
SweetAndLow
Sweet'NASty
richcj10
I have looked at the IBM ServeRAID M1015 but it doesn't have SFF-8088 port required. Looking at the second link I have tried flashing the card but to no avail.
Can't you get an adapter cable from SFF-8087 to SFF-8088? Otherwise, this card looks like it should do the trick.
richcj10
I didn't know that thoes kind of adapters existed. Good thought. The card listed in the link may work. I will have to see if it is compatible with the jbod array
Sent from my SM-N910T using Tapatalk
richcj10
I ordered the card danb35 found. Can't wait to try it.
richcj10
It worked. I wanted to state it here for future reference.
The card was a Avago LSI SAS9200-8e and I used a Rackable Systems SE3016.
Thanks for your help.
