Yatti420
- Aug 12, 2012
I recently noticed WD released 6TB red drives upping their capacity aswell as WD Red Pros with extended warranties depending on intended use.. I just wanted to see what everybody is running right now and your specific drives have failed etc.. I want to run this with a series of polls but I'm not sure if this is possible with the current forum setup or with without multiple threads.. I'll compile the results and upload later..
Edit: I may use a polling site to allow for quicker / easier response.. If you feel anything should be added drop a comment below..
If I cant do it via polls (preferred in 1 thread) I will create a template to follow..
Which type of hard drive do you use (connection)?
______________________
Have you had any of these drives fail? If so how many and for what reason?
If applicable at what time did your drive fail?
- SATA
- SAS
- PATA/IDE
- USB Drive Setup
- 1TB or Under
- 2TB
- 3TB
- 4TB or Greater
- Standard Desktop Use (WD Blues / non-nas drives)
- Standard NAS use (WD Reds / NAS intended drives)
- Enterprise Grade Use (WD Raptors etc / Enterprise specd drives)
