What does a FreeNAS public key look like?
mvcad
Hi All,
We bought a Freenas mini-xl to upgrade our current synology box so I am trying to set up an rsync task to migrate all data over the weekend. I've been trying to use this guide : https://www.mattwall.co.uk/2016/04/03/rsync-to-synology-from-freenas.html but I got stuck in the part when I have to paste the public key into a field in Freenas GUI and also paste it into the authorized_keys file on our synology. when printing the Freenas public ID it looks like this: ssh-rsa + {SPACE} + averylongchainofcharacters + {SPACE} + user1@freenas.local.
so my question is: should I include the strings "ssh-rsa" and "user1@freenas.local" as part of the key when pasting it to the public key field? and also when pasting it into the authorized_keys file?
As you can imagine I cannot ssh to my synology without typing a password, which is ultimately what I want to do.
system : Freenas mini XL running Freenas 11.1 U5, 4 X 4TB WD reds in RAIDZ2 with mirrored samsung EVO SSD for ZIL (SLOG)
TIA.
jgreco
Resident Grinch
@m0nkey_ is basically correct. The authorized_keys file lists authorized keys, one per line. You have to make sure that the id_rsa.pub from the source system gets entered as a single line. In some cases, you may need to prepend additional arguments such as
from="1.2.3.4",command="/foo/bar" ssh-rsa <big ssh key> <user@host>
which would only allow the key to be used from the IP 1.2.3.4 and would only allow /foo/bar to be executed. This isn't generally required. However, I explain it so that you can understand the importance of having this as a single line, as you could list dozens or hundreds of authorized keys in this file, so you do actually need to make sure the key is entered cleanly on a single line.
mvcad
Thank you all, I managed to copy my public id using ssh-copy-id command. However I am using a windows 10 machine with putty so when copying the key from putty into Freenas GUI I am not sure if I am doing it correctly. Can I simply copy and paste from putty to FN GUI opened In firefox? Is there any better method?
HoneyBadger
actually does care
Administrator
When I copied an id_rsa.pub from PuTTY on a Windows machine, it showed up in the paste buffer as a single line:
ssh-rsa AAAAAreallylonglineofgibberishhere username@hostname.domain
Pasting directly into the Firefox window should work. Failing that you could use WinSCP to copy the actual id_rsa.pub file to your local machine, open it with Notepad, and then make sure it's not trying to word-wrap it for some reason?
jgreco
Resident Grinch
Depending on the terminal emulation and settings being used, PuTTY may or may not break at the right hand edge when pasting.
If you know how to use "vi", you can use "$" to go to the end of the line, and if it isn't actually correct, you can "J" to join the following line, and then "x" to get rid of the whitespace that it replaces the end-of-line character with. Given the length of an SSH key, you might need to do that more than once.
Or you can open a reeeeeallllly wiiiiiiiiiiiide putty.
m0nkey_
If you're going to lure new users to vi, at least give them a link on how to exit vi!
https://stackoverflow.com/questions/11828270/how-to-exit-the-vim-editor
But there is nothing more satisfying than seeing a new vi user do this:
^c^c^c^c^cquitexit^x^xN*(&$C#p98uco[cifdjs;fodwtfbbq! *hits reset switch*
Protip: To exit vi, press escape to go into normal mode, then type :q to quit. If you want to save changes and quit type :wq or exit without saving changes type :q!.
wblock
Documentation Engineer
User-friendly tip: ee is present on FreeNAS. It's a normal, non-modal screen editor with an onscreen menu showing key commands. Home and End keys should work, too.
That one seems to fly under the radar a lot. nano is installed too, so you shouldn't ever have to deal with vi.
jgreco
Resident Grinch
Yeah, but both ee and nano are crap at this sort of thing.
If I was going to lure new users to vi, I wouldn't have used the words "If you know how to use vi."
How so? OK, use nano -w then--it disables word wrap. It's simple, it works well. Or you can use an ancient torture device which can be beaten into submission and used to edit text.
For some of us grumpy old Unix farts, vi is the editor of choice. That's the way it was, and we liked it! :)
jgreco
Resident Grinch
Now you have to use the right command line flags? "Geez."
At this point it is probably better to note that you can do "cat >> ~/.ssh/authorized_keys" at the command line, paste in the text, hit carriage return, then control-D.
Well, sure, if you recite the proper incantations in the dead of night, hold your tongue at the right angle, and wave a dead chicken, I'm sure you can make it do what you need...
Past tense?
It was a Dana Carvey Saturday Night Live! reference. I still like it. As I said, it is still my editor of choice. Then again, the first Unix I used was Xenix (Licensed port by Microsoft) System III on an Altos system powered by an 80186. Yes, I know that makes me old...
