currently I try to setup an rsync job to backup my files from TrueNAS to a remote Synology NAS that is connected to my network through a VPN.
I found this guide: https://www.mattwall.co.uk/2016/04/03/rsync-to-synology-from-freenas.html
He is creating the SSH key with 'ssh-keygen' on the TrueNAS command line.
I generated the key through the GUI since someone told me in the past "In FreeNAS you should do everything in the GUI".
If I try to create the rsync job I get the following message:
"In order to use rsync over SSH you need a user with a private key (DSA/ECDSA/RSA) set up in home dir."
Have I done anything wrong? Is it possible to use the key generated by the GUI?
Where is it stored? Should I just symlink it to
Why is there a possibility to create SSH keys in the GUI when I can't select them in rsync tasks?
/root/.ssh/id_rsa
?Why is there a possibility to create SSH keys in the GUI when I can't select them in rsync tasks?
