I just upgraded to 21.08 Beta1 from 21.06.
But now, I can't reach the WebUI using the hostname (in my case nas2.local), I tried both http:// and https://
I can access it with the IP address of both NIC's.
Is this due a broken config? I had to tinker with the network config, because the VM's couldn't ping the host (did it pre 21.06). Setup a bridge and give it the IP address from the Interface and delete it form the physical interface.
Also, the NAS shows up in "Network" on a Win10 machine, but it can't be accessed if you click on it. (Error Message 0x80070035 – The network path was not found)
Thanks for any help.
