Web UI tables not rendered properly
xcentric
Hi everyone, I have some problem with FreeNAS tables not being rendered properly, so wherever I have some table for an example in "Jails" and when I click on the dropdown button in order to extend the options for some of them that extended area height is too low so I need to scroll up and down but there is a ton of room. (Check my screenshot)
I'm a web developer so I could tweak it with some script in for example Tempermonkey but I'm searching for some long term solution.
Thanks in advance!
laskeyp
I know this is an old issue but I want to give it a bump. This is the one thing that drives me nuts about FreeNAS and now TrueNAS. I have spent days scouring forums for a solution but this post is the only mention I have ever come across. With tons of real-estate, the jails list (expanded or not) only shows a very few lines and requires constant scrolling to use. Why is this list so severely limited in size? I would love to find a setting to fix this. Failing that, an http hack would do just as well.
