So my first post as a FreeNAS noob and I need some help.
OS : FreeNas 9.3 Stable
Hardware:
So to my problem, I setup the initial data volume via the manual GUI (due to mismatched drive sizes) and created a cifs share which was viewable from other machines on my network. As a test I started to copy a large dataset of photos (1.6tb) to the new volume and after about an hour my FreeNAS box crashed (Think I saw the word panic in the reboot sequence). Upon reboot it hung at initializing the volume for a very long time ~30 - 45 minutes. Eventually when I was able to get back onto the GUI it showed my volume as degraded, and the 4TB WD drive was out of the volume. Looking the disks in the GUI, it showed up but didn't have an serial number associated with it. I then deleted the volume and did a clean reboot, after which the serial number reappeared on the WD drive. However I don't trust the drive now so I started to run the hard drive burn-in test. I initially ran the smartctl -t short test, it stated it would take 5 minutes but after an hour it hadn't completed so I aborted it and re-ran it. Its been several hours now and its still stuck with 10% remaining?
Do I need to have the drive replaced or is there some other test I should be or can be doing?
Thanks
Hardware:
- Lenovo TS140
- Core i3 Processor
- 8GB RAM (4 x 2G ECC UDIMM's)
- 2X8GB (Kingston, Not yet but to be mirrored for boot)
- 3x1Tb Hitachi Deskstar 7K1000
- 1 x4Tb WD Red
Model Family: Western Digital Red (AF)
Device Model: WDC WD40EFRX-68WT0N0
Serial Number: WD-WCC4E4AP49LE
LU WWN Device Id: 5 0014ee 2612a77f3
Firmware Version: 82.00A82
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sun Apr 5 15:12:24 2015 EDT
SMART support is: Enabled
General SMART Values:
was never started.
Self-test execution status: ( 241) Self-test routine in progress...
10% of test remaining.
data collection: (51720) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 517) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 100 253 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 100 253 021 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 2
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 001 001 000 Old_age Always - 65535
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 45
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 2
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 0
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 1
194 Temperature_Celsius 0x0022 107 106 000 Old_age Always - 45
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
ATA Error Count: 1
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 1 occurred at disk power-on lifetime: 40 hours (1 days + 16 hours)
ER ST SC SN CL CH DH
04 61 00 53 4f c2 40 Device Fault; Error: ABRT
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
b0 d8 00 01 4f c2 40 08 01:25:57.869 SMART ENABLE OPERATIONS
ec 00 01 00 00 00 40 08 01:25:57.479 IDENTIFY DEVICE
ec 00 01 00 00 00 40 08 01:25:48.748 IDENTIFY DEVICE
ec 00 01 00 00 00 40 08 01:25:37.587 IDENTIFY DEVICE
# 1 Short offline Interrupted (host reset) 10% 40 -
# 2 Short offline Completed without error 00% 30 -
# 3 Short offline Completed without error 00% 15 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay.Thanks
