SOLVED WD Red 8TB drives make clicking noise
Platter7
In my new build rig I found out that my four brand new WD Red 8TB drives make a clicking noise every 5 seconds.
When the sata cables are not connected the clicking stops. Different sata cables and different sata port make no difference.
I've searched the forum and found nothing much but this thread:
https://forums.freenas.org/index.php?threads/hdd-heartbeat-at-idle.40899/
Outcome unclear however
according to WD the noise seems to be normal...
https://support.wdc.com/knowledgebase/answer.aspx?h=p2&ID=20933&lang=en&p=2005
Wonder what your experience, advise or opinion is with these kind of noises...
This is the outcome of smart of one of the drives... they seem to be ok...
Model Family:	 Western Digital Red
Device Model:	 WDC WD80EFAX-68KNBN0
Serial Number:	VAG57EVL
LU WWN Device Id: 5 000cca 099c261cf
Firmware Version: 81.00A81
User Capacity:	8,001,563,222,016 bytes [8.00 TB]
Sector Sizes:	 512 bytes logical, 4096 bytes physical
Rotation Rate:	5400 rpm
Form Factor:	  3.5 inches
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:	Thu Oct 18 20:07:22 2018 CEST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
										was completed without error.
Self-test execution status:	  (   0) The previous self-test routine completed
										been run.
data collection:				(   87) seconds.
capabilities:					(0x5b) SMART execute Offline immediate.
										command.
										Self-test supported.
SMART capabilities:			(0x0003) Saves SMART data before entering
										power-saving mode.
Error logging capability:		(0x01) Error logging supported.
Short self-test routine
recommended polling time:		(   2) minutes.
Extended self-test routine
recommended polling time:		( 871) minutes.
SCT capabilities:			  (0x003d) SCT Status supported.
										SCT Data Table supported.
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x000b   100   100   016	Pre-fail  Always	   -	   0
  2 Throughput_Performance  0x0004   127   127   054	Old_age   Offline	  -	   112
  3 Spin_Up_Time			0x0007   157   157   024	Pre-fail  Always	   -	   516 (Average 520)
  4 Start_Stop_Count		0x0012   100   100   000	Old_age   Always	   -	   36
  5 Reallocated_Sector_Ct   0x0033   100   100   005	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x000a   100   100   067	Old_age   Always	   -	   0
  8 Seek_Time_Performance   0x0004   128   128   020	Old_age   Offline	  -	   18
  9 Power_On_Hours		  0x0012   100   100   000	Old_age   Always	   -	   422
 10 Spin_Retry_Count		0x0012   100   100   060	Old_age   Always	   -	   0
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   36
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   52
193 Load_Cycle_Count		0x0012   100   100   000	Old_age   Always	   -	   52
194 Temperature_Celsius	 0x0002   171   171   000	Old_age   Always	   -	   38 (Min/Max 19/58)
196 Reallocated_Event_Count 0x0032   100   100   000	Old_age   Always	   -	   0
197 Current_Pending_Sector  0x0022   100   100   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0008   100   100   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x000a   200   200   000	Old_age   Always	   -	   0
SMART Error Log Version: 1
No Errors Logged
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline	Aborted by host			   60%		16		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
(END)
No Errors Logged
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
...skipping...
No Errors Logged
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
That drive got hot... 58 celsius. you should be keeping it at or under 35-40 on average.
Platter7
So I see. It took me some time before getting the fanscript (spinpid2.sh) to work, further I had a 140mm noctua-fan which just quit spinning due to a wrong threshold.
still I was not aware of this rather extreme temperature... it was not for a very long time though.
Arwen
Could be the heads parking. Not usual for NAS drives. My media server has a laptop drive in it, and it does head parking too much. So I disabled that function. Can't tell you how to do it on FreeNAS, (my media server runs Linux).
cods69
The only time I've ever heard clicking sounds from drives is when they are about to die (or are dead), or there is not enough consistent/adequate power. That's not to say that something else can't cause this, such as something nasty in the SATA connection/controller, etc.
Head parking every 5 seconds is not normal, in any scenario.
Platter7
I checked the disks again, also by connecting them one by one to another motherboard. After some testing I found out that is was actually one disk making the clicking noise (also referred to as the click of death..). Apparently I made a mistake by not disconnecting this specific disk during earlier testing (it was late...). After sending the clicking harddisk back to the supplier I received a new disk the same week! The clicking-noise is gone!
All in all it was very educating to see how FN reacts after rebooting when I had disconnected one or more disks from a pool, as was to see how one could replace a failed disk easily by a new one and restoring the pool.
