humboldtcorrado
- Feb 22, 2014
my specs:
HP z600, dual xeon 2ghz processors, 24gigs ECC, 4x 2tb WD HD's set up in RAID-Z2.
running sab, sickbeard, couchpotato, and PMS on FreeNAS 9.2.1.2.
everything was working perfectly until last night. i got a notification in boxcar on my phone that Couchpotato updated itself. cool.
i checked it out this morning, and the interface for CP was all messed up. weird. i stopped CP's jail, and turned it back on. i got this message across the top of my screen:
i couldn't turn the CP plugin back on. i hit the switch to turn it from off to on, and it just jumps right back to off. i deleted the plugin/jail, and reinstalled, and it now works fine. i restarted the server just for kicks, and now Sickbeard and Sab both don't turn on, and i get the "warden exception" error when i turn the jails off and back on. if i try to turn the plugins back on, i get the same thing i had with CP (the switch just kicks itself back off).
i found this bug report, but it seems like they're saying the problem was with a particular build. i'm running the release of 9.2.1.2.
help.
edit: i should mention that this same thing happened to me when i upgraded to 9.2.1.2 a couple of weeks ago. i was messing around with installing PlexConnect in its own jail, and just figured i hosed something, so i did a complete clean reinstall of FreeNAS, and everything has been fine until last night. also, Plex has been running fine in both of these instances, and doesn't seem to be effected in the same way that the other plugins are.
warden_exception('Shared object "libintl.so.9" not found, required by "python"\n',)i couldn't turn the CP plugin back on. i hit the switch to turn it from off to on, and it just jumps right back to off. i deleted the plugin/jail, and reinstalled, and it now works fine. i restarted the server just for kicks, and now Sickbeard and Sab both don't turn on, and i get the "warden exception" error when i turn the jails off and back on. if i try to turn the plugins back on, i get the same thing i had with CP (the switch just kicks itself back off).
help.
