warden exception?
my specs:
HP z600, dual xeon 2ghz processors, 24gigs ECC, 4x 2tb WD HD's set up in RAID-Z2.
running sab, sickbeard, couchpotato, and PMS on FreeNAS 9.2.1.2.
everything was working perfectly until last night. i got a notification in boxcar on my phone that Couchpotato updated itself. cool.
i checked it out this morning, and the interface for CP was all messed up. weird. i stopped CP's jail, and turned it back on. i got this message across the top of my screen:
warden_exception('Shared object "libintl.so.9" not found, required by "python"\n',)
i couldn't turn the CP plugin back on. i hit the switch to turn it from off to on, and it just jumps right back to off. i deleted the plugin/jail, and reinstalled, and it now works fine. i restarted the server just for kicks, and now Sickbeard and Sab both don't turn on, and i get the "warden exception" error when i turn the jails off and back on. if i try to turn the plugins back on, i get the same thing i had with CP (the switch just kicks itself back off).
i found this bug report, but it seems like they're saying the problem was with a particular build. i'm running the release of 9.2.1.2.
help.
edit: i should mention that this same thing happened to me when i upgraded to 9.2.1.2 a couple of weeks ago. i was messing around with installing PlexConnect in its own jail, and just figured i hosed something, so i did a complete clean reinstall of FreeNAS, and everything has been fine until last night. also, Plex has been running fine in both of these instances, and doesn't seem to be effected in the same way that the other plugins are.
thanks for the link. i'll pop in there and add to the report. for what it's worth, it looks like Plex wasn't working either - it would stream all my media, but wouldn't update after adding any new media. i had to uninstall/reinstall that too, and it was fixed.
just posting here to keep track... i was messing around with sickbeard and it started acting funky this afternoon. i stupidly rebooted, and all my jails lost their minds again. i brought the server back up, and once again, i couldn't turn on any of the plugins. i got pissed off and installed another fresh copy of 9.2.1.2 onto my flashdrive and re-autoimported my data drive and installed all the plugins again. i went through the setup process on all the plugins, and didn't have any issues, until... the Sab plugin went through the initial config process and went to reboot, and wouldn't come back up. i uninstalled/reinstalled the plugin again, and everything seems to be working correctly, for now. this is very frustrating.
shawly
I got the exact same exception on 9.2.1.2... I installed SABnzbd, XDM and BTSync and a Jail with MySQL.
Has somebody got a solution for this problem?
after this happened to me a half-dozen times, i rolled back to 9.2.0 and haven't really had too many problems since. it seems to be much more stable for me.
