Wake on Lan
Devilstompa
Hello I have free nas all installed I'm trying to figure out how to create a wake on lan so it will turn on. Thanks. I'm also having a hard time trying to find the ip and mac address.
That would have to be an IPMI/BMC function (aka Cisco CIMC, HP iLo, Dell DRAC, etc).
Devilstompa
Is there a way I can set it up ?
You didn't list your hardware config. Please do that. Does your hardware have IPMI or some kind of BMC?
Devilstompa
I'm actually running a rampage gene 3 motherboard and intel 960. I know it's not a real server but it's what I have. The bios has wake on lan. Just wondering how I do it thanks
That depends on your BIOS. You have to send a properly formatted WoL message to the MAC address of the machine.
Devilstompa
How do I find the mac address. I tried looking in bios. Can i find it through freenas ? Thanks
While FreeNAS is up, ifconfig -a from the command line.
Devilstompa
I will try that thanks.
Devilstompa
I got it all setup working thank you alot. I can turn it on from my phone now
