Volume state is degraded
spyder
"The volume xxxxx state is DEGRADED: One or more devices are faulted in response to persistent errors. Sufficient replicas exist for the pool to continue functioning in a degraded state."
I may be over my head here.
System Information
Hostname freenas.local Edit
Build FreeNAS-11.1-U1
Platform AMD FX(tm)-4100 Quad-Core Processor
Memory 11736MB
System Time Thu, 26 Jul 2018 16:35:12 -0700
Uptime 4:35PM up 54 days, 46 mins, 0 users
Load Average 0.38, 0.24, 0.13
I can't figure out where to look to start solving this problem. I am not a genius tech. I know enough to be dangerous.
Any kindness would be greatly appreciated.
S
m0nkey_
Output of zpool status would be useful.
Paste it here using the [ code ] tags
spyder
errors: No known data errors
  pool: spyro
 state: DEGRADED
status: One or more devices could not be opened.  Sufficient replicas exist for
action: Attach the missing device and online it using 'zpool online'.
   see: http://illumos.org/msg/ZFS-8000-2Q
  scan: scrub repaired 0 in 0 days 00:09:33 with 0 errors on Sun Jul 15 00:09:36 2018
	   NAME											STATE	 READ WRITE CKSUM
	   spyro										   DEGRADED	 0	 0	 0
		 raidz2-0									  DEGRADED	 0	 0	 0
		   5914224077538151657						 UNAVAIL	  0	 0	 0  was /dev/gptid/17be84be-09e6-11e8-824f-94de803fa
3c5
		   gptid/19458cab-09e6-11e8-824f-94de803fa3c5  ONLINE	   0	 0	 0
		   gptid/1abd9ec2-09e6-11e8-824f-94de803fa3c5  ONLINE	   0	 0	 0
		   gptid/1cae3f1d-09e6-11e8-824f-94de803fa3c5  ONLINE	   0	 0	 0
		   gptid/1e2c231a-09e6-11e8-824f-94de803fa3c5  ONLINE	   0	 0	 0
		   gptid/1ff9c623-09e6-11e8-824f-94de803fa3c5  ONLINE	   0	 0	 0
Redcoat
spyder
Thanks everyone for your patience. I will attempt to replace this weekend.
CraigD
Well done, you found a way to survive a drive failure without losing data!
Your data was still live and accessible even after losing a drive, most people lose data or have to use a backup copy.
Have Fun
spyder
So . . When I took it apart, I found a SATA cable that was intermittent. Problem solved - Thanks everyone!
