One of the disks was took out from the NAS mistakenly and the current pool status is showing as degraded.
Alert message:
Web GUI is not accessible at the moment but ssh is still working
zpool status is showing as below:
Can someone give any idea how to fix this? thanks in advance
Alert message:
Device: /dev/da4, SMART Failure: HARDWARE IMPENDING FAILURE TOO MANY BLOCK REASSIGNS Device: /dev/da4, failed to read SMART values The volume default state is DEGRADED: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected. Device: /dev/da4, Read SMART Self-Test Log Failed
root@freenas:~ # zpool status pool: default state: DEGRADED status: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected. action: Determine if the device needs to be replaced, and clear the errors using 'zpool clear' or replace the device with 'zpool replace'. see: http://illumos.org/msg/ZFS-8000-9P scan: scrub repaired 392K in 17h35m with 0 errors on Sun Nov 26 17:35:48 2017 config: NAME STATE READ WRITE CKSUM default DEGRADED 0 0 0 raidz2-0 DEGRADED 0 0 0 gptid/87859b23-f7e5-11e5-bbbf-0025909b4d4a ONLINE 0 0 0 gptid/8a77d7c9-f7e5-11e5-bbbf-0025909b4d4a ONLINE 0 0 0 gptid/8d67c8a1-f7e5-11e5-bbbf-0025909b4d4a ONLINE 0 0 0 1255253969284545076 REMOVED 0 0 0 was /dev/gptid/9057d78c-f7e5-11e5-bbbf-0025909b4d4a gptid/93449ee9-f7e5-11e5-bbbf-0025909b4d4a ONLINE 0 0 2 gptid/962b228d-f7e5-11e5-bbbf-0025909b4d4a ONLINE 0 0 0 gptid/9918cd79-f7e5-11e5-bbbf-0025909b4d4a ONLINE 0 0 0 gptid/9c0990fc-f7e5-11e5-bbbf-0025909b4d4a ONLINE 0 0 0 logs gptid/9cad6899-f7e5-11e5-bbbf-0025909b4d4a ONLINE 0 0 0 cache ada0p1 ONLINE 0 0 0 errors: No known data errors pool: freenas-boot state: ONLINE scan: scrub repaired 0 in 0h1m with 0 errors on Tue Dec 19 03:46:57 2017 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 da8p2 ONLINE 0 0 0 errors: No known data errors
