VM remove error: "dataset does not exist" after data loss
julian35152
Good morning,
I tried something with LanCache during the night and then the Raid-0 controller went down.
But as you can see in the picture and in the errorlog: I can't delete the VM from the webinterface now.
Is there a trick in the shell or something to delete it?
Error&Setup below.
Error:
Error: concurrent.futures.process._RemoteTraceback:
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/zfs.py", line 848, in do_delete
    subprocess.run(
  File "/usr/local/lib/python3.8/subprocess.py", line 512, in run
    raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command '['zfs', 'destroy', 'Raid0/LanCache-jhfxpf']' returned non-zero exit status 1.
  File "/usr/local/lib/python3.8/concurrent/futures/process.py", line 239, in _process_worker
    r = call_item.fn(*call_item.args, **call_item.kwargs)
  File "/usr/local/lib/python3.8/site-packages/middlewared/worker.py", line 91, in main_worker
    res = MIDDLEWARE._run(*call_args)
  File "/usr/local/lib/python3.8/site-packages/middlewared/worker.py", line 45, in _run
    return self._call(name, serviceobj, methodobj, args, job=job)
  File "/usr/local/lib/python3.8/site-packages/middlewared/worker.py", line 39, in _call
    return methodobj(*params)
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/zfs.py", line 860, in do_delete
    raise CallError(f'Failed to delete dataset: {error}', errno_)
middlewared.service_exception.CallError: [EFAULT] Failed to delete dataset: cannot open 'Raid0/LanCache-jhfxpf': dataset does not exist
The above exception was the direct cause of the following exception:
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 137, in call_method
    result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self,
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1195, in _call
  File "/usr/local/lib/python3.8/site-packages/middlewared/service.py", line 471, in delete
    rv = await self.middleware._call(
  File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 973, in nf
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/vm.py", line 1492, in do_delete
    await self.middleware.call('zfs.dataset.delete', disk_name)
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1238, in call
    return await self._call(
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1203, in _call
    return await self._call_worker(name, *prepared_call.args)
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1209, in _call_worker
    return await self.run_in_proc(main_worker, name, args, job)
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1136, in run_in_proc
    return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1110, in run_in_executor
Setup:
The RAID controller makes a Raid-0 from 4 1TB disks.
This raid is simply included in Truenas as a separate pool.
I created an Ubuntu VM in Truenas on the pool and allocated 2TB.
After a while the controller crashed.
No chance to set it back up!
I had to remove it because it made my Truenas totally unusable. (for whatever reason, no login to the web interface, etc.)
You could take some inspiration from this post and create the dataset with matching names to have something for the GUI to remove...
julian35152
Worked.
THX
Somehow logically. have also thought of something like that, but thought that then any unique data are missing!
I have click zombie style createt a pool. and a dataset mit the old names. Worked!
