mammutserver
 - Sep 20, 2020
I created a virtual machine for Ubuntu on my FreeNAS server. Virtualization is enabled in the BIOS (see the settings in the picture below).
I tried different things from different forums but the virtual machine still exits with this errormessage:
[EFAULT] VM NextcloudVM failed to start: 20/09/2020 16:50:04 Listening for VNC connections on TCP port 5714 20/09/2020 16:50:04 Listening for VNC connections on TCP6 port 5714 ROM boot failed: unrestricted guest capability not available fbuf frame buffer base: 0x882e00000 [sz 16777216]
File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 130, in call_method
io_thread=False)
File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1084, in _call
return await methodobj(*args)
File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 961, in nf
File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/vm.py", line 1016, in start
await self._manager.start(vm)
File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/vm.py", line 53, in start
list(done)[0].result()
File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/vm.py", line 350, in run
raise CallError(f'VM {self.vm["name"]} failed to start: {output}')
middlewared.service_exception.CallError: [EFAULT] VM NextcloudVM failed to start: 20/09/2020 16:50:04 Listening for VNC connections on TCP port 5714
io_thread=False)
