Can't replace a USB boot device, 11.3 : Operation not permitted
diskdiddler
Long unecessary story short, I'm attempting to replace a USB drive in a system.
Maybe I don't know how to do it?
I went into
System : Boot : Actions (Boot pool status)
I can see the degraded disk, with "faulted"
I can neither "replace" OR "detach" the faulted drive.
Errors are:
"[EZFS_NOREPLICAS] no valid replicas" for detach.
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/zfs.py", line 247, in __zfs_vdev_operation
op(target, *args)
File "libzfs.pyx", line 369, in libzfs.ZFS.__exit__
op(target, *args)
File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/zfs.py", line 256, in <lambda>
self.__zfs_vdev_operation(name, label, lambda target: target.detach())
File "libzfs.pyx", line 1774, in libzfs.ZFSVdev.detach
libzfs.ZFSException: no valid replicas
File "/usr/local/lib/python3.7/concurrent/futures/process.py", line 239, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.7/site-packages/middlewared/worker.py", line 95, in main_worker
res = loop.run_until_complete(coro)
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 579, in run_until_complete
return future.result()
File "/usr/local/lib/python3.7/site-packages/middlewared/worker.py", line 51, in _run
return await self._call(name, serviceobj, methodobj, params=args, job=job)
File "/usr/local/lib/python3.7/site-packages/middlewared/worker.py", line 43, in _call
return methodobj(*params)
File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 964, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/zfs.py", line 256, in detach
File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/zfs.py", line 249, in __zfs_vdev_operation
raise CallError(str(e), e.code)
middlewared.service_exception.CallError: [EZFS_NOREPLICAS] no valid replicas
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 130, in call_method
io_thread=False)
File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1077, in _call
return await methodobj(*args)
File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 960, in nf
File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/boot.py", line 214, in detach
await self.middleware.call('zfs.pool.detach', 'freenas-boot', dev)
File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1127, in call
app=app, pipes=pipes, job_on_progress_cb=job_on_progress_cb, io_thread=True,
File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1074, in _call
return await self._call_worker(name, *args)
File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1094, in _call_worker
return await self.run_in_proc(main_worker, name, args, job)
File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1029, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1003, in run_in_executor
If I choose replace, it lists some disks, I see member disk da0 (I believe to be my 3'rd USB key, my 'hotspare')
"[EFAULT] 'newfs_msdos -F 16 /dev/da0p1' failed: newfs_msdos: /dev/da0p1: Operation not permitted "
io_thread=False)
File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/boot.py", line 226, in replace
boottype = await self.format(dev, format_opts)
File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/boot.py", line 114, in format
raise CallError('%r failed:\n%s%s' % (" ".join(command), p.stdout.decode("utf-8"), p.stderr.decode("utf-8")))
middlewared.service_exception.CallError: [EFAULT] 'newfs_msdos -F 16 /dev/da0p1' failed:
diskdiddler
No seriously though, eventually this single USB key will sting me, how do I replace it?
Jailer
Not strong, but bad
Save your config, install FreeNAS on new boot device, boot server, upload saved config, reboot.
It's all in the manual.
diskdiddler
I figured this was one option, reluctant to do it.
Wouldn't my configuration from the old system include the bad disk ID for the USB drive?
I'll give it a shot, it's pretty unlikely to ruin anything if I recall.
