Stealthbird
- May 30, 2020
Hello Everyone,
I am in a spot of bother and need some assistance.
I am running Freenas on a tower server with internal storage and also have an external disk array connected via fibre channel. Broken into two tanks depending on whether or not it's internal (lo_tank) or external (ext_tank)
Unfortunately, I've lost a drive in my external disk array and as I am not physically able to replace the drive (I am currently working in the USA until January, and my server is located in my home in the UK) I decided it was best to just shut down the disk array.
My jails and some plugins were running on this ext_tank, but I would now like to spin up some jails in the lo_tank.
I am having issues switching the jails system from ext_tank to lo_tank. I know I can't access the old jails, I just want to make new ones, but the system will not let me activate the lo_tank for jails or plugins and throws errors.
When I open the jail page in the gui.
ZFSException
cannot open 'ext_tank': pool I/O is currently suspended
I clear this message and go to "choose pool for Plugin and Jail Storage", and then get this
CallError
[EFAULT] Failed to activate lo_tank: cannot open 'ext_tank': pool I/O is currently suspended
How can I get around this. I don't see why the tank that the jails are currently, and the fact that it is inaccessible, prevents me changing to a new jail.
System Config
FreeBSD 11.3-RELEASE-p7 (FreeNAS.amd64)
Hopefully someone can help me with this.
Kind Regards
ZFSException
File "/usr/local/lib/python3.7/site-packages/iocage_lib/zfs.py", line 20, in run
cp.check_returncode()
File "/usr/local/lib/python3.7/subprocess.py", line 444, in check_returncode
self.stderr)
subprocess.CalledProcessError: Command '['zfs', 'get', '-H', '-o', 'property,value', 'all', 'ext_tank']' returned non-zero exit status 1.
File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 130, in call_method
io_thread=False)
File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1095, in _call
return await run_method(methodobj, *args)
File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1019, in _run_in_conn_threadpool
return await self.run_in_executor(self.__ws_threadpool, method, *args, **kwargs)
File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1007, in run_in_executor
File "/usr/local/lib/python3.7/concurrent/futures/thread.py", line 57, in run
File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 965, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/jail.py", line 914, in get_activated_pool
pool = ioc.IOCage(skip_jails=True, reset_cache=True).get('', pool=True)
File "/usr/local/lib/python3.7/site-packages/iocage_lib/iocage.py", line 95, in __init__
self.pool = PoolAndDataset().get_pool()
File "/usr/local/lib/python3.7/site-packages/iocage_lib/iocage.py", line 66, in get_pool
return ioc_json.IOCJson().json_get_value("pool")
File "/usr/local/lib/python3.7/site-packages/iocage_lib/ioc_json.py", line 1321, in __init__
super().__init__(location, checking_datasets, silent, callback)
File "/usr/local/lib/python3.7/site-packages/iocage_lib/ioc_json.py", line 428, in __init__
self.pool, self.iocroot = self.get_pool_and_iocroot()
File "/usr/local/lib/python3.7/site-packages/iocage_lib/ioc_json.py", line 552, in get_pool_and_iocroot
pool = get_pool()
File "/usr/local/lib/python3.7/site-packages/iocage_lib/ioc_json.py", line 453, in get_pool
if pool.active:
File "/usr/local/lib/python3.7/site-packages/iocage_lib/pools.py", line 27, in active
return Dataset(self.name, cache=self.cache).properties.get(
File "/usr/local/lib/python3.7/site-packages/iocage_lib/dataset.py", line 38, in __init__
self._properties = deepcopy(cache.datasets.get(self.resource_name))
File "/usr/local/lib/python3.7/site-packages/iocage_lib/cache.py", line 22, in datasets
ioc_pool = iocage_activated_pool()
File "/usr/local/lib/python3.7/site-packages/iocage_lib/zfs.py", line 97, in iocage_activated_pool
if dataset_properties(pool).get('org.freebsd.ioc:active') == 'yes':
File "/usr/local/lib/python3.7/site-packages/iocage_lib/zfs.py", line 88, in dataset_properties
return properties(dataset, 'zfs')
File "/usr/local/lib/python3.7/site-packages/iocage_lib/zfs.py", line 54, in properties
resource_type, 'get', '-H', '-o', 'property,value', 'all', dataset
File "/usr/local/lib/python3.7/site-packages/iocage_lib/zfs.py", line 22, in run
raise ZFSException(cp.returncode, cp.stderr)
iocage_lib.zfs.ZFSException: cannot open 'ext_tank': pool I/O is currently suspendedI clear this message and go to "choose pool for Plugin and Jail Storage", and then get this
CallError
self.stderr)
File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/jail.py", line 1316, in activate
iocage.activate(pool['name'])
File "/usr/local/lib/python3.7/site-packages/iocage_lib/iocage.py", line 361, in activate
pool.deactivate_pool()
File "/usr/local/lib/python3.7/site-packages/iocage_lib/pools.py", line 53, in deactivate_pool
Dataset(self.name, cache=self.cache).set_property(
io_thread=False)
File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/jail.py", line 1318, in activate
raise CallError(f'Failed to activate {pool["name"]}: {e}')
middlewared.service_exception.CallError: [EFAULT] Failed to activate lo_tank: cannot open 'ext_tank': pool I/O is currently suspended
System Config
Kind Regards
