Stealthbird
- May 30, 2020
Hello Everyone,
I am in a spot of bother and need some assistance.
I am running Freenas on a tower server with internal storage and also have an external disk array connected via fibre channel. Broken into two tanks depending on whether or not it's internal (lo_tank) or external (ext_tank)
Unfortunately, I've lost a drive in my external disk array and as I am not physically able to replace the drive (I am currently working in the USA until January, and my server is located in my home in the UK) I decided it was best to just shut down the disk array.
My jails and some plugins were running on this ext_tank, but I would now like to spin up some jails in the lo_tank.
I am having issues switching the jails system from ext_tank to lo_tank. I know I can't access the old jails, I just want to make new ones, but the system will not let me activate the lo_tank for jails or plugins and throws errors.
When I open the jail page in the gui.
ZFSException
cannot open 'ext_tank': pool I/O is currently suspended
I clear this message and go to "choose pool for Plugin and Jail Storage", and then get this
CallError
[EFAULT] Failed to activate lo_tank: cannot open 'ext_tank': pool I/O is currently suspended
How can I get around this. I don't see why the tank that the jails are currently, and the fact that it is inaccessible, prevents me changing to a new jail.
System Config
FreeBSD 11.3-RELEASE-p7 (FreeNAS.amd64)
Hopefully someone can help me with this.
Kind Regards
ZFSException
Error: Traceback (most recent call last): File "/usr/local/lib/python3.7/site-packages/iocage_lib/zfs.py", line 20, in run cp.check_returncode() File "/usr/local/lib/python3.7/subprocess.py", line 444, in check_returncode self.stderr) subprocess.CalledProcessError: Command '['zfs', 'get', '-H', '-o', 'property,value', 'all', 'ext_tank']' returned non-zero exit status 1. During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 130, in call_method io_thread=False) File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1095, in _call return await run_method(methodobj, *args) File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1019, in _run_in_conn_threadpool return await self.run_in_executor(self.__ws_threadpool, method, *args, **kwargs) File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1007, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) File "/usr/local/lib/python3.7/concurrent/futures/thread.py", line 57, in run result = self.fn(*self.args, **self.kwargs) File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 965, in nf return f(*args, **kwargs) File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/jail.py", line 914, in get_activated_pool pool = ioc.IOCage(skip_jails=True, reset_cache=True).get('', pool=True) File "/usr/local/lib/python3.7/site-packages/iocage_lib/iocage.py", line 95, in __init__ self.pool = PoolAndDataset().get_pool() File "/usr/local/lib/python3.7/site-packages/iocage_lib/iocage.py", line 66, in get_pool return ioc_json.IOCJson().json_get_value("pool") File "/usr/local/lib/python3.7/site-packages/iocage_lib/ioc_json.py", line 1321, in __init__ super().__init__(location, checking_datasets, silent, callback) File "/usr/local/lib/python3.7/site-packages/iocage_lib/ioc_json.py", line 428, in __init__ self.pool, self.iocroot = self.get_pool_and_iocroot() File "/usr/local/lib/python3.7/site-packages/iocage_lib/ioc_json.py", line 552, in get_pool_and_iocroot pool = get_pool() File "/usr/local/lib/python3.7/site-packages/iocage_lib/ioc_json.py", line 453, in get_pool if pool.active: File "/usr/local/lib/python3.7/site-packages/iocage_lib/pools.py", line 27, in active return Dataset(self.name, cache=self.cache).properties.get( File "/usr/local/lib/python3.7/site-packages/iocage_lib/dataset.py", line 38, in __init__ self._properties = deepcopy(cache.datasets.get(self.resource_name)) File "/usr/local/lib/python3.7/site-packages/iocage_lib/cache.py", line 22, in datasets ioc_pool = iocage_activated_pool() File "/usr/local/lib/python3.7/site-packages/iocage_lib/zfs.py", line 97, in iocage_activated_pool if dataset_properties(pool).get('org.freebsd.ioc:active') == 'yes': File "/usr/local/lib/python3.7/site-packages/iocage_lib/zfs.py", line 88, in dataset_properties return properties(dataset, 'zfs') File "/usr/local/lib/python3.7/site-packages/iocage_lib/zfs.py", line 54, in properties resource_type, 'get', '-H', '-o', 'property,value', 'all', dataset File "/usr/local/lib/python3.7/site-packages/iocage_lib/zfs.py", line 22, in run raise ZFSException(cp.returncode, cp.stderr) iocage_lib.zfs.ZFSException: cannot open 'ext_tank': pool I/O is currently suspended
CallError
Error: Traceback (most recent call last): File "/usr/local/lib/python3.7/site-packages/iocage_lib/zfs.py", line 20, in run cp.check_returncode() File "/usr/local/lib/python3.7/subprocess.py", line 444, in check_returncode self.stderr) subprocess.CalledProcessError: Command '['zfs', 'get', '-H', '-o', 'property,value', 'all', 'ext_tank']' returned non-zero exit status 1. During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/jail.py", line 1316, in activate iocage.activate(pool['name']) File "/usr/local/lib/python3.7/site-packages/iocage_lib/iocage.py", line 361, in activate pool.deactivate_pool() File "/usr/local/lib/python3.7/site-packages/iocage_lib/pools.py", line 53, in deactivate_pool Dataset(self.name, cache=self.cache).set_property( File "/usr/local/lib/python3.7/site-packages/iocage_lib/dataset.py", line 38, in __init__ self._properties = deepcopy(cache.datasets.get(self.resource_name)) File "/usr/local/lib/python3.7/site-packages/iocage_lib/cache.py", line 22, in datasets ioc_pool = iocage_activated_pool() File "/usr/local/lib/python3.7/site-packages/iocage_lib/zfs.py", line 97, in iocage_activated_pool if dataset_properties(pool).get('org.freebsd.ioc:active') == 'yes': File "/usr/local/lib/python3.7/site-packages/iocage_lib/zfs.py", line 88, in dataset_properties return properties(dataset, 'zfs') File "/usr/local/lib/python3.7/site-packages/iocage_lib/zfs.py", line 54, in properties resource_type, 'get', '-H', '-o', 'property,value', 'all', dataset File "/usr/local/lib/python3.7/site-packages/iocage_lib/zfs.py", line 22, in run raise ZFSException(cp.returncode, cp.stderr) iocage_lib.zfs.ZFSException: cannot open 'ext_tank': pool I/O is currently suspended During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 130, in call_method io_thread=False) File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1095, in _call return await run_method(methodobj, *args) File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1019, in _run_in_conn_threadpool return await self.run_in_executor(self.__ws_threadpool, method, *args, **kwargs) File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1007, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) File "/usr/local/lib/python3.7/concurrent/futures/thread.py", line 57, in run result = self.fn(*self.args, **self.kwargs) File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 965, in nf return f(*args, **kwargs) File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/jail.py", line 1318, in activate raise CallError(f'Failed to activate {pool["name"]}: {e}') middlewared.service_exception.CallError: [EFAULT] Failed to activate lo_tank: cannot open 'ext_tank': pool I/O is currently suspended
System Config
Kind Regards
