vbox guest additions
zxoot45
Hope this is where to ask
Not sure how to install the vbox G/additions.iso in the jail?
Thanx in advance
Also it's amazing how freely you all help each other out just because you can.
Anywhere you want. You just have to mount it in the VM to install it...
zxoot45
Thank you
When you say VM do you mean the vm jail or the guest os.
if it helps i'm trying to mount windows.
also would that robolinux work or even be able to?
that would be nice, more secure. (what is claimed)
You have to mount the ISO to the VM. So you have to put the ISO somewhere that the jail has access to, then mount the ISO for the VM to use it.
Honestly, this should be common knowledge to anyone that has used a type-2 hypervisor before. This should be trivial to implement and do.
