SOLVED error installing vbox extension pack
jaaassh
Hi!
Ultimately, I'm trying to figure out how I can RDP into a vbox guest so that I can walk through ubuntu and windows OS installs. The way I understand it, I need to have the vbox extension pack installed. I downloaded the 4.3.12 version from here:
http://dlc-cdn.sun.com/virtualbox/4.3.12/index.html
...because the version of VboxManage is also 4.3.12:
root@virtualbox:~ # VBoxManage --version
4.3.12_OSEr93733
When I go to install the extension pack, I get an error:
root@virtualbox:~ # VBoxManage extpack install /mnt/data/Oracle_VM_VirtualBox_Extension_Pack-4.3.12-93733.vbox-extpack
0%...
Progress state: NS_ERROR_FAILURE
VBoxManage: error: Failed to install "/mnt/data/Oracle_VM_VirtualBox_Extension_Pack-4.3.12-93733.vbox-extpack"
VBoxManage: error: Failed to locate the main module ('VBoxPuelMain')
VBoxManage: error: Details: code NS_ERROR_FAILURE (0x80004005), component ExtPackManager, interface IExtPackManager
VBoxManage: error: Context: "int handleExtPack(HandlerArg*)" at line 1143 of file VBoxManageMisc.cpp
Is this supported currently, and if so, are there any troubleshooting steps I could apply?
Thanks for the help!!
Robert Trevellyan
Pony Wrangler
You should be able to work with any guest by enabling its Remote Display server and connecting with any VNC client. The VirtualBox extension pack is not required. Am I missing something?
jaaassh
Thanks!
I enabled RDP from the guest's settings under Display -> Remote Display.
