so i've been trying to find a solution to get this working. ive googled and searched the forums. i can't get a new VM to boot up. i keep receiving a VERR_SUPLIB_OWNER_NOT_ROOT error. i've tried to strip down the VM to bare specs (no nic, no cd drive, no floppy), but still the same error. It's a Win2012 VM.
https://forums.virtualbox.org/viewtopic.php?f=7&t=39179
the thread above points it to a permission issue, but ive tried setting chown, chgrp, and chmod on the /home folder within the jail but no luck. maybe someone here can help. i've also tried re-installing freenas 9.2.1.8 from scratch and deleting/installing the jail, but errors still occurs. this is what shows up in the machine log...
any help is much appreciated!
VirtualBox VM 4.3.12_OSE r93733 freebsd.amd64 (Jun 12 2014 05:56:47) release log 00:00:00.020403 Log opened 2014-11-14T06:06:52.305576000Z 00:00:00.020404 Build Type: release 00:00:00.020424 OS Product: FreeBSD 00:00:00.020428 OS Release: 9.1-RELEASE 00:00:00.020432 OS Version: FreeBSD 9.2-RELEASE-p12 #0 r262572+b043649: Sun Sep 28 23:03:31 PDT 2014 root@build3.ixsystems.com:/tank/home/jkh/build/921/freenas/os-base/amd64/fusion/jkh/921/freenas/FreeBSD/src/sys/FREENAS.amd64 00:00:00.020441 Host RAM: 24546MB total, 6002MB available 00:00:00.020443 Executable: /usr/local/lib/virtualbox/VBoxHeadless 00:00:00.020444 Process ID: 35958 00:00:00.020444 Package type: BSD_64BITS_GENERIC (OSE) 00:00:00.042538 Installed Extension Packs: 00:00:00.042562 VNC (Version: r0; VRDE Module: unusable because of 'The owner is not root: '/usr' (rc=VERR_SUPLIB_OWNER_NOT_ROOT)') 00:00:00.045942 pdmR3LoadR0U: pszName="VMMR0.r0" rc=VERR_SUPLIB_OWNER_NOT_ROOT szErr="The owner is not root: '/usr'" 00:00:00.045973 VMSetError: /wrkdirs/usr/ports/emulators/virtualbox-ose/work/VirtualBox-4.3.12/src/VBox/VMM/VMMR3/VM.cpp(594) int vmR3CreateU(UVM*, uint32_t, int (*)(UVM*, VM*, void*), void*); rc=VERR_SUPLIB_OWNER_NOT_ROOT 00:00:00.045977 VMSetError: Failed to load VMMR0.r0 00:00:00.046107 ERROR [COM]: aRC=NS_ERROR_FAILURE (0x80004005) aIID={8ab7c520-2442-4b66-8d74-4ff1e195d2b6} aComponent={Console} aText={Failed to load VMMR0.r0 (VERR_SUPLIB_OWNER_NOT_ROOT)}, preserve=false 00:00:00.068963 Power up failed (vrc=VERR_SUPLIB_OWNER_NOT_ROOT, rc=NS_ERROR_FAILURE (0X80004005))
